Jason Underwood
TryHard W.A Manual V8 UZZ31
Posts: 118 Reg: 07-2007
| Hey guys, I have been contemplating supercharging my V8 for a few years now and I always get to thinking, Is it worth the big bucks you have to lay down to get some extra 50hp. I have seen a few that are blown and only pushing around 280rwhp. My N/A pushes 240 at the moment and was just wondering how much boost can you run from a twin screw system if it is intercooled. I would like to get around the 350rwhp mark, (Dreaming I know). But could it be done. I would like to stay away from the turbocharged option. Any info guys would be great. |
Gianni Matrogiannis
TryHard nsw SC400 V8
Posts: 173 Reg: 08-2005
| i have more than 350 rwhp with my set up |
Jason Underwood
Posts: 119 Reg: 07-2007
| Great work Gianni, who did the work for you? What model Vortech are you using. |
Gianni Matrogiannis
Posts: 174 Reg: 08-2005
| i did all the work on it, im unsing a v2 sq vortech, |
Paul Drane
DieHard QLD V8 Limited
Posts: 569 Reg: 07-2005
| 311 RWHP on a stock motor, original ECU, exhaust, fuel pump. and a rising rate fuel reg. No intercooling and 8lbs of boost, on a Whipple twin screw, bit more than 50 hp increase.
that is from a baseline of 128 RWKW to start with. |
Posts: 3203 Reg: 03-2006
| Is your car a manual paul? cause the peak power doesnt match the road spee dfor a 3rd gear dyno run? |
Kim Hunt
Tinkerer nsw Supercharged SC400 GT-L UZZ31
Posts: 66 Reg: 08-2007
| the answer is yes it is worth it |
Paul Drane
Posts: 570 Reg: 07-2005
| Its an auto Daniel, for some reason mine hits the rev limit at 5900 revs and wont rev any higher. An after market ECU is being looked into, havent decided what one yet. Supercharging is definitely worth it. |
Posts: 3204 Reg: 03-2006
| Yeah explains the lack of speed on the dyno.. Kinda weird hey? You wont regret an Ecu Paul |
Goo Roo North Island JZZ31
Posts: 3455 Reg: 10-2005
| Dynos don't tell you everything. I've never driven a supercharged Soarer, but the supercharged car's I have driven have been much more fun to drive than the bottom line power figures would make you think. Of course if quarter mile times and dyno readouts are what you are interested in, then you might be better of getting a JZZ30. |
Goo Roo NSW I have a Cadillac and a Supercharged Manual V8
Posts: 4501 Reg: 07-2005
| If you wanna lift it 3 more Inches Paul, I can intercool it for you |
Paul Drane
Posts: 571 Reg: 07-2005
| I know you can Neil, and the thought has crossed my mind. Have you intercooled your Silvia yet? |
Posts: 4504 Reg: 07-2005
| Should be within the next 2 weeks Paul. I also have my local engineer CNCÃng a setup for the Twin Screw. So I will be able to have a FMIC with either an M112 or Twin Screw. |
Paul Drane
Posts: 573 Reg: 07-2005
| Sounds good Neil. Intercooled twin screw on LPG, youre gonna kick some arse with that. |
Posts: 4506 Reg: 07-2005
Paul Drane
Posts: 574 Reg: 07-2005
Brett Moloney
DieHard Queensland Supercharged UZZ31
Posts: 704 Reg: 07-2005
| Now that is old school Tuff!!! |
Posts: 4507 Reg: 07-2005
| Aristo's Blower gets bolted down tomorrow. |
Posts: 4508 Reg: 07-2005
Steven Anderson
TryHard NSW UZZ31 Manual
Posts: 225 Reg: 05-2006
| that looks way tough neil. You would have to do 2 bonnets though, 1 with the hump for road legalness and 1 with just a cut bonnet for cruising. And it looks like your car has way more power in it Paul, even with the current setup. All you need is an ECU to lean the mix a little and raise the rev limit as the power is still going up when it stops! |
Posts: 4511 Reg: 07-2005
Michael Long
TryHard victoria UZZ31
Posts: 242 Reg: 03-2006
| SICK!!!! |
Steven Anderson
Posts: 226 Reg: 05-2006
| some of this kinda stuff next http://www.youtube.com/watch?v=YAiBVkfqsm4 |
Tai Johnsen
TryHard QLD UZZ31 - V8
Posts: 478 Reg: 04-2006
| HOLY S*#T !!! That guy can hold down an accelerator AND turn the steering wheel!!!! Looks like it under-steers like a mofo too... But yes, some circle work is definitely in order |
Brendon O'Loughlin
TryHard NSW v8
Posts: 146 Reg: 07-2005
| Neil, what kind of figures are you getting/expecting to on that. Which supercharger headunit are you using? |
Posts: 4516 Reg: 07-2005
| Brendon, I would guess about 160RwKw ( There abouts ) YT1500 Charger. |
Posts: 4518 Reg: 07-2005
Tai Johnsen
Posts: 484 Reg: 04-2006
| That looks tough as! |
Steven Anderson
Posts: 231 Reg: 05-2006
| making all the v8 boys (including me!) drool neil. is it w2a intercooled or a test for ata? |
Scott Casey
Tinkerer nsw soarer v8
Posts: 43 Reg: 02-2008
| Neil, standing on top of the engine bay to take the pic. i would not dare to do that. ha, if i saw someone did that to my car for any reason they would have died twice before they have hit the ground |
Posts: 4522 Reg: 07-2005
Steven Anderson wrote on Sunday, April 06, 2008 - 09:31 pm:is it w2a intercooled or a test for ata?
No cooler at the moment. When its 100mm higher, it will have a Front Mount A2A.
Scott Casey wrote on Monday, April 07, 2008 - 09:40 am:Neil, standing on top of the engine bay to take the pic. i would not dare to do that.
My car is TOUGH as nails..hahhaha All GO, no SHOW... |
Steven Anderson
Posts: 233 Reg: 05-2006
| 100mm!! gonna need a big scoop! *click* ah so thats the first photos above with the wood block... heh. |
