  Soarer Central * Mechanical - V8 - Supercharged * Emv tv Previous Previous    Next Next
Shadi Khodr
vic
v8
Tuesday, March 22, 2011 - 12:28 pm, by:  Shadi Khodr (Mr_sammy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i want to put a emv tv in my soarer 1991 model , i know a few wreckers that have one are they easy to install
Michael Toet
Reg: 06-2009
Tuesday, March 22, 2011 - 12:45 pm, by:  Michael Toet (Myke31) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have to ask why?
Do you mean the TV or the EMV screen itself? If you don't have one, then you'd need to mod the aircon etc. Look for the posts on EMV->Climate control conversion. You'd need to do the reverse. Then you'd have to get the radio, DSP and stacker (maybe even the main amp and sub amp). Then, unless the radio has been modified you'd have one station (or get an FM expander). On top of that, they are old, the back lights can fail, the inverter can fail etc. I had mine repaired and it cost me $450 or there abouts. I would have been better off putting that into a climate control conversion and after market touch screen.
I am currently looking for another Soarer. The reason is I want to simplify, no airbags, no EMV. I also want something with a sun roof, so they're not the only reasons, but it is one less thing to break.
If you don't have one, I'd advise keeping it simple, and putting in an aftermarket 7" touch screen.
Vincent Chan
v8
Reg: 12-2010
Tuesday, March 22, 2011 - 01:05 pm, by:  Vincent Chan (Vincent191) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I agree with Michael. Others are trying to get away from the EMV screen and you want to put one in? There is another thread and someone else want to convert his coilovers with airbags.
To answer your question, it is not easy. You have to at least mod your air & radio and still end up with a few useless buttons.
James Buchan
Reg: 10-2008
Wednesday, March 23, 2011 - 11:38 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm getting rid of my EMV. I've got the TT climate control to install, and will source a new head unit too. Should be heaps more simple.
Christian Somerville
UZZ31 V8 LTD
Reg: 03-2009
Thursday, March 24, 2011 - 09:15 am, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is your emv a supercharged V8?
Kim Hunt
Supercharged & Intercooled SC400\Soarer GT-L UZZ31
Reg: 08-2007
Saturday, April 09, 2011 - 11:10 pm, by:  Kim Hunt (Lxtasi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
james do you want to sell your emv?
