Tuesday, May 17, 2011 - 03:27 pm, by: Matthew Carillo(Italian_techno)
After trying to get every last bit of cheap power out of my 1UZ i have decided to try a SC14 and see what the results are.
I know a lot of people think the SC14 is far to small but my points are.
1. I have an SC14 lying around doing nothing 2. Commodore v6 boys get 7psi out of them and the v6 is only .2l smaller that the 1UZ (3.8lv6 - 4.0v8) aswell as the 1uz wont need to rev as much as the V6 so overrunning the SC won't be to much of a problem.
God only knows how I will fit this in the engine bay,
Tuesday, May 17, 2011 - 06:25 pm, by: Allan Langford(Allan)
ohhh no not this again...
I'm going to be course with you due to your lack of use of the search feature, but considering your low post count I may forgive you in the future!
Now on with the grilling...
Horsepower is a direct result of how much air you flow though a motor and that is limited by its volumetric efficiency (VE), any type of forced induction such as supercharging or turbo-charging increase the engines VE, VE is not tied to an engines displacement.
also superchargers and turbo-chargers have an efficiency curve similar to engines, so while a SC14 is only ~20cc smaller then a Eaton M90 displacement wise its two lobe rotor design is VERY inefficient.
a M90 will struggle to make >9psi on a 1uz, requiring them being spun to >14000rpm with VERY hot discharge temps.
a SC14 has a redline of 12000rpm
a Commodore v6 is a 2 valve per cyl bucket of manure that struggles to make 146rwkw, chiped, cam'ed, ported and tuned:
