  Soarer Central * Mechanical - V8 - Supercharged * M90 needs more power Previous Previous    Next Next
Scott Vim
Soarer (1uz) Chaser (1jz)
Reg: 12-2010
Thursday, June 26, 2014 - 08:28 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey I've got an m90 running 5psi putting out a very disappointing 175rwkw. I'm thinking either running a smaller pulley or reshimming the tappets. What do you guys think will net the most power gains. The m90 is a master for heat so not sure about the gains of more boost. No intercooler or water injection. Opinions?
James Buchan
vvt-i turbo
Reg: 10-2008
Thursday, June 26, 2014 - 09:53 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
People will say upgrade to a twin screw, HTV1900 etc, but I know you'll be sticking with the M90.
Maybe a meth injection kit, and a smaller pulley for a little more boost?
Also, un-related but I know the cams in the 1UZ are not that aggressive, maybe if you scored some cams from a wreck and got some place like Kelford to do a re-grind, maybe that might net you a little bit more power?
Scott Vim
Reg: 12-2010
Friday, June 27, 2014 - 12:33 am, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I measured the pulley its 3.2 inch's.
Andrew Brown
V8 6 Speed Manual
Reg: 10-2012
Friday, June 27, 2014 - 12:41 am, by:  Andrew Brown (Crazyassdrummerboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Upgrade to m112, simple... should use same manifold
Dave van Staveren
Soarer Limited coupe Supercharged V8
Reg: 03-2011
Wednesday, July 02, 2014 - 10:43 pm, by:  Dave van Staveren (Deveous) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My pulley measures just a tad under 2 1/2 inches. Done 196kw at 7psi at our Soarer club dyno day. Played around with a few things since then and it is making a little more boost. Its pushing around 9 psi on boost gauge now.
Scott Vim
Reg: 12-2010
Thursday, July 03, 2014 - 07:00 am, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So standard injectors not possible? Where did you get the pulley from? I think mine is 3.25". Heard its very difficult to get the stock pulley off.
Allan Langford
Reg: 05-2010
Thursday, July 03, 2014 - 10:25 am, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
M90 and M112 are NOT interchangeable on the same manifold
I have the pulley remover / installer tool if you want to borrow it as long as you replace the consumables and agree to the "you broke it you bought it" policy :-)
pulleys for M90 / M112 are GM ecotech 3.8 ones from pulleyboys.com
Standard injectors with raised fuel pressure and after-market ecu top out at 215rwkw
M90's are too marginal on a 3.8 and too small for a 4.0.
Scott Vim
Reg: 12-2010
Thursday, July 03, 2014 - 12:04 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine has got little Allen key bolt on the front of the pulley. Is that by chance a quick change pulley? I bought the car with the charger on it already.
Allan Langford
Reg: 05-2010
Thursday, July 03, 2014 - 12:18 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Post a photo
Scott Vim
Reg: 12-2010
Friday, July 11, 2014 - 08:23 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Allan Langford
Reg: 05-2010
Friday, July 11, 2014 - 09:06 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ahhh I think that is a yellaterra snout
Scott Vim
Reg: 12-2010
Friday, July 11, 2014 - 09:15 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What's that all about. Is the pulley a quick change over one?
Dave van Staveren
Reg: 03-2011
Saturday, July 12, 2014 - 06:08 pm, by:  Dave van Staveren (Deveous) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah that looks to be the Holden style Yella Terra. My pulley is custom and different to yours. You could try these guys, see if one of their smaller pulleys will line up on your application
http://tttperformance.com.au/holdensuperchargedv6vsvy/2
Daryl Demarte
IS300 & UZZ32
Saturday, July 12, 2014 - 06:37 pm, by:  Daryl Demarte (Helieng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Scott,
your pulley will be a quick change unit, with the pulley a close tolerance fit to the flange, held on by the 4 allen screw bolts, same as mine.
Scott Vim
Reg: 12-2010
Saturday, July 12, 2014 - 09:31 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So how quick is the change?
Daryl Demarte
IS300 & UZZ32
Sunday, July 13, 2014 - 05:05 am, by:  Daryl Demarte (Helieng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Undo the 4 bolts, remove the belt, remove the pulley.
Daryl Demarte
IS300 & UZZ32
Sunday, July 13, 2014 - 05:30 am, by:  Daryl Demarte (Helieng) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You might have to change the length of the belt too.
Scott Vim
Reg: 12-2010
Wednesday, July 23, 2014 - 08:15 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Other path I'm considering is water/meth injection but I was reading apprantly its bad for the m90 blowers internals. Is this true or not? What kindbof gains are to be expected with or without tuning?
Brett Harrison
Friday, July 25, 2014 - 04:41 pm, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Some of the holden v6 boys make big power with the m 90, perhaps look at some of those for ideas.
Gavin Johnstone
Reg: 11-2010
Friday, July 25, 2014 - 08:30 pm, by:  Gavin Johnstone (Zedrift) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i was thinking of doing this with water/meth nozzles post charger straight into the manifold =)
Scott Vim
Reg: 12-2010
Saturday, July 26, 2014 - 05:45 am, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
https://www.alcohol-injection.com/forum/supercharged-engines/2352-dyno-tunning-results-4-0lt-1uz-m90 -6psi-boost.html
30rwkw gain.
Ali Saeed
RSP JZZ30
Saturday, July 26, 2014 - 02:16 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mate of mine with a m90 on a 1uz soarer just got a safe tune for 290rwhp. I believe he has full header back exhaust, upgraded fuel pump and a motec.
Tuner reckons E85 would net 30+rwhp
Damon Picard
Soarer GT-Limited V8 UZZ31
Reg: 05-2014
Sunday, July 27, 2014 - 01:08 pm, by:  Damon Picard (Dejayp) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Was he still running the stock injectors Ali?
Ali Saeed
RSP JZZ30
Monday, July 28, 2014 - 03:48 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
We arent a 100% sure...but they certainly look stock (havent pulled it apart to check)
Scott Vim
Reg: 12-2010
Monday, July 28, 2014 - 10:26 am, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How much boost?
Scott Vim
Reg: 12-2010
Monday, July 28, 2014 - 01:32 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bullet says they have a pulley for my charger 67mm. Current one is 80mm what's the average boost gain from this. They say about 2psi. I'm running about 5psi on an 80mm now.
Dave van Staveren
Reg: 03-2011
Tuesday, July 29, 2014 - 08:17 am, by:  Dave van Staveren (Deveous) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That should put you at around 190kw ATW (250+ a bit HP) but the torque difference is the impressive bit.
Scott Vim
Reg: 12-2010
Thursday, July 31, 2014 - 10:15 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://m.youtube.com/watch?v=JI89NO7_jLE&feature=youtu.be
Scott Vim
Reg: 12-2010
Friday, August 01, 2014 - 02:45 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone know what my m90 would be worth if I sold it as a kit or just sold it with the top plate (not the manifold)?
Scott Vim
Reg: 12-2010
Thursday, August 07, 2014 - 01:59 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A machinist took 4mm off the ribs of the pulley today. Should be running a couple more psi. My pulley is the old style that sits over the neck of the blower. So a smaller pulley won't actually fit. (Will rub on the neck of charger). Will be sure to get it tuned. Water injection going in. Hopefully to break into the 200rwkw barrier.
Scott Vim
Reg: 12-2010
Wednesday, August 13, 2014 - 08:14 pm, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
On the dyno today. Made 180rwkw when it went in. Boost was up by roughly 1 psi at around 6 psi. It made 190rwkw without any water injection. Then we turned water injection on. Comes on only at full boost and made 200rwkw. It is not tuned for water so if it fails the car will run fine without it. Gives me a gain of 10rwkw just being there. It actually seems to have balls now. Shifting is brutal and it even sounds a bit different. I done a few little repairs since it was last tuned. I didn't want to tune around water injection in case of pump failure. I bought a second hand kit from josh and I had some trouble with the pump. Josh has been very good about it and is a good seller. Hopefully it holds up and I'm the future more boost will go in.
James Buchan
vvt-i turbo
Reg: 10-2008
Wednesday, August 13, 2014 - 09:55 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So far, very positive results. I will be keen to go for a spin with you soon to see the difference first hand.
