Is there an easy way to move the plastic case that covers the wiring at the rear of the motor? I have trimmed it back and it is still in the way. Looks like I need to actually remove the plastic case.
John Stafford Goo Roo Qld. Soarer UZZ31 GT-L V8, limited edition supercharged. 2013 Titanium Territory, Petrol 7 seater, 1JZ twin turbo set up for the track.
Saturday, May 05, 2018 - 06:11 pm, by: John Stafford(Johng12)
Jan, are you just newly fitting a supercharger? You can cut part of that plastic away and cover the wiring with proper shielding to protect it from heat and harm and so have it more flexible to allow you to reroute the loom to the new places that it needs to go with the supercharger fitment. If I remember you have to extend a couple of wires, can't remember perfectly but it should be self-explanatory.
You have to reroute the kick down cable. Getting it around the back of the motor takes a bit of maneuvering but ends up no worries.
The diagnostics plug needs to be rerouted to next to the brake booster too but you probably know all this. All the best.
