Tuesday, August 01, 2006 - 06:30 pm, by: Gary Nimmo(Gazzasore)
Yep thanks Neil I wont know for sure until my SC400 ECU & Unichip & everything is running the way it should eh I asked Joel about making me an 8 psi pulley he said put it all together & see how many psi the 59mm one puts out I think over here in WA to comply the car it must be a 8 psi or less So time will tell
Tuesday, August 01, 2006 - 07:15 pm, by: Neil Griffiths(Aussiesc)
Yep...I agree with Joel...No chance in hell of knowing what PSI a pulley will give.. A Fresh Clean air filter will even change the boost reading,,hahahahah Try to get the best air filter mate. Like Apexi Etc...Dont skimp like I do.. ( I bought a crate of aftermarket ones,,so I am trying to consume em )
Friday, August 11, 2006 - 06:40 pm, by: Gary Nimmo(Gazzasore)
Will do thanks Neil Things are looking good though Everything went together & fitted easily Fuel reg leaked like a sive a Malpassi will need to upgrade my Hose clamps etc they keep breaking I think the Unichip will have to go on sooner than later
Friday, August 11, 2006 - 10:59 pm, by: Gary Nimmo(Gazzasore)
I took the cold start hose off & plugged it up with a 8mm bolt hard to find one with the right thread Have taken off the Toyota fuel reg too I used the old fitting of the Brake booster vacuum The fitting fits fine where the old fuel reg was Its all plumed right What are these soft grip champs the banjo fitting aren't a problem & yes I'm looking forward to your new setup You are doing engine mods then
Saturday, August 12, 2006 - 07:31 am, by: Neil Griffiths(Aussiesc)
R & D is so much fun. aint it..hahahahahah
For any more answers Gaz, I will ONLY do it through email on the condition you do not share the info.. ( Because you have purchased my products, I will assist you, if needed )
