  Soarer Central * Mechanical - Common * Can't get the key out of the ignition Previous Previous    Next Next
Open in new windowArchive through September 05, 2005Benny Gammelmark20
Brett Moloney
Monday, September 05, 2005 - 03:52 pm, by:  Brett Moloney (Lxsv8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had same problem and to fix I had to redo the 3 Grub Screws on the shifter till I found the correct adjustment. Now all is good and looks great too!
Kevin la Terra
soarer GTTL
Monday, September 05, 2005 - 05:12 pm, by:  Kevin la Terra (Trdpsi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thats exactly what happend to mine about a month ago
when she finally let go of the keys i sprayed a LITTLE bit of wd40 and it has never happend again
Kerry Boehm
v8
Tuesday, September 06, 2005 - 07:40 am, by:  Kerry Boehm (Kjbee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Benny and Joseph,
A cyber big hug to both of you. After a bit of fiddling it works really well. Thanks again for your support.
Kerry
Joseph Reno
'91, 2.5GT-T-L JZZ30-ACPZZ
Tuesday, September 06, 2005 - 08:18 am, by:  Joseph Reno (Gamer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Glad you got it sorted..
Here is a little tip. I always carry one of the Allen keys in the car to tighten up the screws as I had mine come loose once due to being a little heavy handed. You might want to have one at hand in case the same happens while your out.
Tuesday, September 06, 2005 - 12:33 pm, by:  Benny Gammelmark (Oldfield) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Me too. I would think, wait a couple of days and re-tighten the screws.
Brett Moloney
Tuesday, September 06, 2005 - 12:49 pm, by:  Brett Moloney (Lxsv8) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep - Allen Key lives in centre console
