  Soarer Central * Mechanical - Common
Open in new windowCat converter?Boris Siljanoski
Open in new windowFuel smell ---- please helpNatasha D'Abreo10
Open in new windowRadiator leakMarc Hoffmann
Open in new windowOil ConsumptionPeter Nitschke
Open in new windowOne tough crankshaft bolt...Marc Hoffmann36
Open in new windowPIGGY BACK ECU QUESTIONScott Casey13
Open in new window1uz removalMichael Brown16
Open in new windowSoarer airbag questionAdam Foster
Open in new windowWheel studsAli Saeed
Open in new windowAir flow meterBoris Siljanoski
Open in new windowSoarer stallingMark Donovan20
Open in new windowOverheating?Nickel Quimada
Open in new windowCeramic coatingJames Buchan11
Open in new windowFord Telstar 80's model - broke down. General questions...David Boyle
Open in new windowFluids flushScott Wilkes
Open in new windowRear Upper control arms (bushings) InstallationMatchy Loi
Open in new windowGeneral Cat Q: Melbourne: Need a pit to get at cats (again)...Costa Tsimiklis
Open in new windowBFI Problems - unable to drive car properlySimon Trainos
Open in new window1uzfe conversion. HelpMichael Brown
Open in new windowDiff oil and tranny oil flushMatthew Sharpe
Open in new windowWater pump blown?Karl Martin
Open in new windowJust want to know the cc inside a stock head chamber cheersDaniel Jeyes
Open in new windowSafe jack point to raise front of car?Matthew Sharpe
Open in new windowRounded Spark PlugDave Rose14
Open in new windowV8 upper radiator hoseRobert Davies
Open in new windowPower Steering - Can't Believe It..........Christian Somerville46
Open in new windowPower Steering Fluid for TTSandesh Welikala22
Open in new windowDecarbonizationAusten Menze27
Open in new windowFinished my BFIAusten Menze
Open in new windowStainless Steel Twin ExhaustsMike Beck
Open in new windowEFI 52???Scott Casey
Open in new window2.4L VVTI replace our current 3.0 or 4.0 engines!!!George Lu24
Open in new windowOils aint oilsMatchy Loi10
Open in new windowBattery clamp size?Adam Lonergan
Open in new windowSUPER URGENT - ABOUT TO JUMP STARTMiles Baker36
Open in new windowFuel savers (Air vortex) snake oil?Mike Bradberry27
Open in new windowEngine Missing/Misfiring - V8 SoarerMike Bradberry16
Open in new windowNeed help for oxygen sensorAlan Kuo
Open in new windowFuel tank replacement.Brett Cutts
Open in new windowMelbourne wreckers that may have Soarers?Robert Faggian
Open in new windowFuel system q'sEvan Kaio
Open in new windowDoing my own service. Check list helpTom Richards
Open in new windowCoolingSpencer Cameron11
Open in new windowPower steering woesMarc Hoffmann
Open in new windowDigital Tune up?Matthew Sharpe14
Open in new windowCats may be stuffedJethro Sims
Open in new windowSpark plug lead questionJol Alexander
Open in new windowAxle tramping, need some adviceScott Wilkes
Open in new windowAbout to change leads - any advice?Jol Alexander
Open in new windowGood method of cleaning an engine (outside)?Evan Kaio15
Open in new windowPlease confirm hoses for power steeringTom Richards
Open in new windowSoarer Specialist in QLDJaime Laurente
Open in new windowFUEL FILTER FOR 3LTRDaniel Clarke
Open in new windowPs pump tt and v8 are they the sameTom Richards
Open in new windowSloppy Steering Rob Rojo
Open in new windowCatch Can InstallBen Lipman20
Open in new windowInterior still leakingGreg Dugan
Open in new windowHot engine cut-out?Evan Kaio35
Open in new windowBlown rear sealScott Wilkes29
Open in new windowFuel filler brokenDaniel Clarke
Open in new windowThermalsDavid Vaughan72
Open in new windowNeed HelpBenny Johns
Open in new windowEbay water pumps, Any problems?James Harris19
Open in new windowDifferent Power steering pump... What do I do?Joe Russell
Open in new windowOil line leaks- is there a thread tape I can use?Ben Lipman
Open in new windowPlease help -stalling auto everytime car turns on or idolsMike Dobkin26
Open in new windowPower Steering Pump Help Needed pleaseAndrew Ferres
Open in new windowTO4Z turbo resultsBlake Gloyn
Open in new windowEngine Wont Start First TimeRalph Cooke12
Open in new window knockings in the motor.Andrew Ferres
Open in new windowWhat does this button do?Kristian Sibum22
Open in new windowPart Numbers Etc - 3.0 2jz non turboMatthew Sharpe
Open in new windowEngine MountsJames Cahir
Open in new windowWhats the trick ???Ben Daniel
Open in new windowMy 3.0 2jz soarer problemsTy Mackay20
Open in new windowPlease Help !Ruwan Perera
Open in new windowSOARER KEEPS FOULING SPARK PLUGS 2 POINT IT WONT RUN PROPERLY!Steven Anderson
Open in new windowShielding the side of the BFI from the engine Ty Mackay
Open in new windowAir filter cleaningTom Renshaw12
Open in new windowNeed an Alternator?Michael Clark
Open in new windowCentrifugal supercharger on a JZZ31???Matthew Sharpe42
Open in new windowI need some advice on oil cooler kits.Ben Lipman
Open in new windowQuick BFI questionScott Wilkes17
Open in new windowCAT light ONAndrew Ferres
Open in new windowURGENT HELP FOR POWER STEERINGBrian Timms
Open in new windowUnichip :-( What's my options??...David Tra
Open in new windowProblem with power steeringLachie Bryce19
Open in new windowSealant Recommendations Michael Keen
Open in new windowCheap Soarer v8? Justin Green19
Open in new windowPower steering hose???Nenad Ristovski
Open in new windowMiss in V8Dave Rose
Open in new windowNoisey tappets V8Tom Richards
Open in new window1jzgte into ef falconDaniel Clarke24
Open in new windowRemove harmonic balancer the easy wayShane Haverkamp
Open in new windowIs This stockBenny Johns
Open in new windowGasket or sealerNettie Barton
Open in new windowRadiator SpecialistVinny Ozorio
Open in new windowEmb HelpDaniel Clarke
Open in new windowIs there a RPM limiter on the V8.David Vaughan15
Open in new windowTop Tank Radiator Crack PicturesAsh Martin
Open in new windowJust picked up a Soarer but it idles at 1,200-1,400Kane Chan
Open in new windowCRC your lock barrels.Mike Beck
Open in new windowGoing to try the old tt p/s flushMatchy Loi
Open in new windowAirbag present?Ben Kelly
Open in new windowAnyone know the size of stock fuel hose?Ben Socratous
Open in new windowVarious issues with my soarerSam Atash
Open in new windowCould this be why my heater isnt working?Ben Lipman
Open in new windowJZZ330 Block Heater?James Harris
Open in new windowV8 Engine missing occasionally when hotMark Ribbans13
Open in new windowGetting beyond a joke...... :-(...Tai Johnsen35
Open in new windowTRD 1.3 bar radiator capBen Socratous
Open in new windowRemote Control Variable Mufflers (pic)Maurice Diggler18
Open in new windowIS300 Chris Lock
Open in new windowEngine Bay Plastic coversAndrew Ferres
Open in new windowSpark plugsMatthew Sharpe
Open in new windowCoil Ignition Lead - heat protection?Neil Griffiths
Open in new windowHand brake tensioningJames Harris
Open in new windowIgnition BarrelEvan Kaio
Open in new windowPOWER STEERING MOTOR VERY NOISYVinh Bui
Open in new windowA 2 stage clunk...Don Bagnall
Open in new windowHigh KM TT'sShane Sartori
Open in new windowDO NOT USE WA Mobile Radiator Repairs - He's a scam artistDave Cazes12
Open in new windowAir Intake SystemBrett Harrison
Open in new windowPower steering unit making a winding noisePeter Nitschke
Open in new windowSlow startBrenton Trafford
Open in new window4.7 LITRE D.O.H.C V8 PETROL Pacemaker Headers PH 12680 Neil Griffiths10
Open in new windowWhat is this?Aaron Holland
Open in new windowPlease help! SLIP CONT OFF & O/D flashing while dash reads SLIP CON...Joshua Rao18
Open in new windowStarter Motor????Brian Timms18
Open in new windowBroken Power steering pump = burst hose?Brian Timms
Open in new windowError messageTim Wyne
Open in new windowDo i need a New Head Gasket?Andrew Keddie10
Open in new window1994 Limited 4.0L V8: Idling Problems After ECU Reset - help! :-(...Daniel Clarke11
Open in new window*** HELP Power Steering Problem ***Mike Bomhoff
Open in new windowCar wont go over 180km/hGlen Muller13
Open in new windowHeavy steering at idlePeter Nitschke
Open in new windowParking antennaRussell Rohde
Open in new windowSunroof MaintenanceBrian Timms17
Open in new windowWhat does a transmission flush cost?Matthew Sharpe12
Open in new windowPower steering pump bearing part numberPeter Nitschke
Open in new windowFuel filter leaking, Need helpAdrain Parsons
Open in new windowBFI Chamber 1 Panel SizesRussell Rohde
Open in new windowFuel pump pick-up/filter bag shenanigans...Tai Johnsen
Open in new window1JZ and 2JZHaydn Crandell
Open in new windowCost of timing belt replacementMike Thomas21
Open in new windowPetrol additivesJeff Bedsor18
Open in new windowV8 Braided Radiator HosesAshley Leach
Open in new windowExterior door handle fix?David Eberhart
Open in new windowAE112 Corolla No oil In Oil Filter After 5000kmTim Appleton
Open in new windowLocked keys in boot!!!Luke Gomer22
Open in new window1jz Fan ClutchBradley Parnell
Open in new windowSerpentine belt squealingBradley Parnell18
Open in new windowRadiator questionBrian Timms
Open in new windowTool recommendation: Actron digital timing lightMiles Baker11
Open in new windowThe Great Aussie Soarer Mechanic GuideGlen Muller59
Open in new windowRestored performance, ecomicallySteve Millward
Open in new windowHelp with power steering hoseJason Underwood
Open in new windowFuel Tank CleanJohn Khanh13
Open in new windowFuel pump ecuAdrain Parsons
Open in new windowFix For Slow Touch ScreenDave Rose
Open in new windowEngine wiring diagrams, Electronic Parts Catalog, Engine Service Ma...Peter Nitschke
Open in new windowConverting v8 soarer to twin turboJoshua Rao12
Open in new windowMelbourne MechanicJames Johnson
Open in new windowPower steering fluid problem or something more sinister?Don Bagnall
Open in new windowSteering arm Nickel Quimada
Open in new windowSteering problemDarryn Dewar
Open in new windowThis message apearing on my dash?Brian Timms
Open in new windowBuying Rotors - Now Impossible!Evan Kaio
Open in new windowA newbie question..well couple of themAli Saeed
Open in new window[VIC] Heater Core replacement.. Where to get it done?Miles Baker19
Open in new windowWhining Noise from power steering pump after reconditioningBuddhika Abeytunga
Open in new windowTime for a new engine?Wafi Cheebo
Open in new windowBest sparkplugs to run, gap and temperature.Mike Thomas55
Open in new windowFan BeltKen Tran10
Open in new windowIs this car worth buying?Richard Baird
Open in new windowCleaning the air intake Maurice Diggler
Open in new window[91 TT] Get my exhaust tomorrow :-)...Robert Petrovski
Open in new windowPurolator oil filtersDave Rose12
Open in new windowClutch Replacement DoneMatthew Sharpe
Open in new windowVictoria - Where to get exhaust / ideal combinationDaniel Lee
Open in new windowStrange idling problem after cruisingBraden Murdoch
Open in new windowJust canged plugs n leadsAlexander Antonescu
Open in new windowTiming Belt - Any advice???Peter Nitschke19
Open in new windowHonda Jazz not pulling up a steep drivewayTim Eacott14
Open in new windowPower steering fluid dissapearing. What does it mean?Scott Ferguson10
Open in new windowEngine coughing/dying at 4500 or .7+ bar boostCihan Aday36
Open in new windowPower mod chip do they workAdam Holloway10
Open in new windowShell 100% racing fuelPhil Gibson30
Open in new windowCarbon BFI LidsJulian Tarman11
Open in new windowNeed pic ASAP - Stock BOVChris Hilton12
Open in new windowCar wont idle...Paul McConnell
Open in new windowHelp Removing Door Handle/LockKurt Porter
Open in new windowHasnt been driven for 3 months. what do i need to do? help asapMatthew Sanderson29
Open in new windowAccident in sydney nees helpZiheng Lu
Open in new windowQuick Test to see if Exhaust is leakingAndrew Hargreaves29
Open in new window2 intercoolers or 1? V8 twin turboDaniel Clarke23
Open in new windowLSD - did Soarers generally come without?David Vaughan51
Open in new windowTT tappets?Kevin la Terra21
Open in new windowBest Type of Spark Plug Leads To Use?Brett Moloney
Open in new windowExhaust clarificationAdrain Parsons12
Open in new windowHKS Coilovers - can they be fixed?Michael Keen14
Open in new windowStrange Error MessageBrett Moloney
Open in new windowPower Steering pump "o" ringPeter Nitschke28
Open in new windowWhat to do about the podSami Ansari10
Open in new window2JZGE exhaustMatthew Sharpe10
Open in new windowFuel Pump ECU - TT same as V8? Or even Aristo/Supra?Paul McConnell
Open in new windowSump plugShaun Stephenson
Open in new windowO2 sensorsDave Hart
Open in new windowV8 Air intake ModificationMichael Folbigg
Open in new windowWarning to all Canadian Soarer Owners About The WindshieldScott Ferguson44
Open in new windowLSD on EbayPhil Gibson
Open in new windowCoolant hoses replacementBraden Murdoch
Open in new windowSquealing NoiseTom McGruther
Open in new windowNeed HelpMichael Howatt11
Open in new windowTrailer Hitch for Soarer:Peter Nitschke28
Open in new windowPlease Help: Soarer 3ltr non turboDon Bagnall11
Open in new windowEngine Oil FilterJuan Landauro
Open in new windowPower Steering... AgainJuan Landauro
Open in new windowCruise Control Dropping OutAdam Peterson21
Open in new windowMisfire at 20 psi - experienced help pleaseBenjamin Burgess13
Open in new windowExaust for my TT.Brian Timms
Open in new windowEngine conversion - 1JZ turbo to 2JZ N/A or V8Paul McConnell35
Open in new windowQuick questionPaul Bernasconi
Open in new windowBrake Pedal PulsationDavid Vaughan14
Open in new windowBrake Flexible HoseJuan Landauro
Open in new windowHeat coating partsRichard Tan
Open in new windowSpark Plugs Removal Soarer 3.0L (Not TT)Matthew Sharpe
Open in new windowSoarer Driver's Door Windowscum on the eath has Brian Timms
Open in new windowProblems with revs, pauses around a certain point...?Paul McConnell
Open in new windowBits loose in the cat ? Alan Chow19
Open in new windowPower Steering main bearing.Jon Millerchip
Open in new windowDarkening Rear View MirrorBrian Timms
Open in new windowFirst issue - power steeringBrian Timms
Open in new windowBrake Upgrade on TTGareth Richards
Open in new windowConverted TT to ManualMarius Hainal
Open in new windowExhaust (temp?) sensorLew Radbourn
Open in new windowV8 parts in TTShane McInnes
Open in new windowMy Complete BFIMark Ribbans
Open in new windowPower Steering Gone.Daniel Trivuncevic
Open in new windowKEYS STUCK IN IGNITIONDaniel Trivuncevic
Open in new windowExclusive to Soarer centralJeff Smith39
Open in new windowAnother Half Yearly something else wrongAdam Lonergan
Open in new windowPower steering blockageMark Paddick
Open in new windowSludge in cooling system advice neededDaniel Clarke10
Open in new windowUnder bonnet detailingGeordie Smith
Open in new windowConstant fuel smell :-( help...Phil Gibson
Open in new windowTechron 5000Gary Chasney
Open in new window.EPC help neededSteve Gorman
Open in new windowShell V-Racing....Rob Andreacchio38
Open in new windowBrand name Injectors - worth the extra cost ?Chris Davey
Open in new windowO2 Sensor... not oscillatingSimon Roberts
Open in new windowMysterious intermittent slow startingSteve Millward
Open in new windowJerk/Throttle holding back even when foot down flat???Nathan Evans
Open in new windowFuel cellBen Socratous
Open in new windowMechanic for 100K service Brisbane - GoldCoastNeil Griffiths19
Open in new windowBrisbane mechanic - Rebuild :-(...Lew Radbourn10
Open in new windowBad power steering noisesMatthew Sharpe
Open in new windowFuel ECU jumper VS Fuel ECU bypassNathan Siy
Open in new windowRemoving power steering power.Haydn Crandell
Open in new windowBuying soarer TT......Callum Finch
Open in new windowTicking noise V8Ashley Leach22
Open in new windowReplacing power steering, rack and pinon, Supra TT upgrade?Michael Brack
Open in new windowSAFC I vs SAFC IIChris Davey12
Open in new windowComputer Engine Simulation - 1jz 2jz 1uzAndrew Ferres
Open in new windowPower steering issues. Any theories?Michael James Madiga
Open in new windowIs replacing an in-tank fuel pump a DIY job?Dominik Bloemhard12
Open in new windowPiston and ConrodCihan Aday
Open in new windowCRACKED TAILSHAFT COUPLINGAvin Luther12
Open in new windowPod Filter... Fuel Economy QuestionMike Beck22
Open in new windowBFI 3 QuestionAshley Leach
Open in new windowV8 missing after degreasing engine bayNik Peacock29
Open in new windowGaugesDamien Smith11
Open in new windowSpark Plugs?Matthew Sharpe18
Open in new windowAirboxAndrew Ferres
Open in new windowFuel Pumps - V8, TT, Same?Don Bagnall
Open in new windowSmoke from the exhaust....AAAAAAHHayden Miller
Open in new windowPS pump fixNeil Griffiths35
Open in new windowHave replaced my 2JZ-GE Cam Belt...Matthew Sharpe11
Open in new windowSurging issues with V8Brett Moloney36
Open in new windowRemoving stock chrome tip coversPeter Nitschke
Open in new windowBUBBLE bubble bubble.....Tai Johnsen
Open in new windowPower Steering PumpBill Bogiatzis27
Open in new windowAnalogue Dash?Steve Anthony De Vos62
Open in new windowTicking sound when cooling downMike Beck14
Open in new windowDriver side electric window, clicking.Perry Morgan
Open in new windowTwin Square Tip MufflersAndrew Ferres15
Open in new windowTo much fuel consumption Richie Lum59
Open in new windowBFI questionMike Beck30
Open in new windowPower steering pump leak?Paul Moulds
Open in new windowTemp gauge position (it's not what you think...)Mark Paddick
Open in new windowBETTER FUEL PUMP...IS IT REALLY?Andrew Ferres
Open in new windowWater PumpsMike Triggs
Open in new windowGenuine Toyota Synthetic OilCihan Aday19
Open in new windowTRC throttle bodyCihan Aday
Open in new windowFront Wheel Bearing Part numbers:Shaun Stephenson
Open in new windowNew Exhaust SystemPhil Gibson35
Open in new windowMegaSoar starts and stalls!!!Perry Morgan15
Open in new windowAnyone had their top radiator tank replaced in Perth?Gary Nimmo30
Open in new windowYet another BFI ThreadAndreas Niaouris35
Open in new windowFuel Cap Door ReleaseAndreas Niaouris
Open in new windowCatalytic Converter Warning Light - different problem ?Tim Appleton
Open in new windowLPG conversion?Matthew Sharpe94
Open in new windowA/F RatioChris Davey21
Open in new windowScary problem with TT. . . Cihan Aday44
Open in new windowFuel pump and injectorsCihan Aday
Open in new window1500 RPM wobble / vibration Tai Johnsen
Open in new windowKAAZ diffsRyan Rankovic13
Open in new windowTurbo Pod Filter, what should i do?Vinh Bui11
Open in new windowWater Pump on 1993 TT soarerBraden Murdoch32
Open in new windowSporadic Overheating - Weird engine tempMark Ribbans12
Open in new windowIt´s alive...Peter Nitschke27
Open in new windowPossible coil problem on v8!!! what can i do to fix itTom Richards
Open in new windowV8 engine dipstickPeter Nitschke
Open in new windowBFI QuestionAdam Underwood38
Open in new windowRear main seal-TTTayne Riley
Open in new window1UZ-FE Lurching Under Hard AccelerationMark Paddick30
Open in new windowExhaust Mods on a vvt-i JZZ31? Don Bagnall19
Open in new windowHose replacementsMike Triggs
Open in new windowUrgent! where to top up transBen Socratous
Open in new windowNewbie + BFI = :-(...Alfred Heng28
Open in new windowBrake System WarningDave Hart23
Open in new windowLosing power in second gear...Mark Paddick14
Open in new windowAdjustable Cam GearsCihan Aday
Open in new windowV8 Starter MotorBrian Haines
Open in new windowFuel Consumption on a UZZ31Mark Donovan24
Open in new windowMy Soarer died...Benjamin Burgess
Open in new windowJust did an oil change now the car sounds funny :?Damien Barnes
Open in new windowA different BFI..Don Bagnall
Open in new windowDisconnecting a speed limiterBen Evans11
Open in new windowSupercharged V8 hits UK roadsTim Staier48
Open in new windowCar stalling on startupEdward Engerer20
Open in new windowPower Steering Pump Reseal...Anish Varsani
Open in new windowLow Idle (have searched & checked ICV)Steve Petkos
Open in new window2JZ-GE harmonic balancer removalMatthew Sharpe
Open in new windowCar not roaring into life...Don Bagnall12
Open in new windowCaltex VortexCraig Austin28
Open in new windowVS commodore problemsAdam Foster18
Open in new windowCar Won't start unless I crank it once and wait. Ben Evans
Open in new windowStrange running problemMike Triggs
Open in new windowCrank shaft sensorChris Davey
Open in new windowSoarer Fuel ConsumptionWill Adams46
Open in new windowCentre hemisphere of an Open wheel soarer (non-lsd centre)Tim Eacott11
Open in new windowFuel consumption before and after, after market engine management.Benjamin Burgess10
Open in new windowGood timing belt guy in SA??Peter Nitschke
Open in new windowOil leakMike Triggs10
Open in new windowJust got Soarer serviced. Came back with extra Problems???Benjamin Burgess19
Open in new window1JZ Idle Issues (Still!)Mike Chandley18
Open in new windowCar Struggling at High RevsMark Paddick10
Open in new windowIntakeMatthew Sharpe17
Open in new windowHow much is there to play with ?Mark Paddick
Open in new windowIdle Worries and QuizJeremy Tennant
Open in new windowCost of RepairRoy Polestico
Open in new windowMechanical issue but not soarer not even toyota sorry in advance Jovica Galovic
Open in new windowO2 sensor fell offDon Bagnall
Open in new windowPresure tap on top of radiator shrould ?????Tim Eacott
Open in new windowExhaust one side hot, one coldCihan Aday18
Open in new window1JZ woes... i need some help please people i am stumped...Chris Davey33
Open in new windowDifficult Philips Head screwsJohn Jantzen22
Open in new windowThrottle BodyNeil Griffiths
Open in new windowSqueaking noise coming from left front or rear wheel!Matthew Sharpe15
Open in new windowUZZ31 Engine MountsDon Bagnall11
Open in new windowPower Steering QuestionDon Bagnall
Open in new windowUZZ30/31/32 Engine MountsJustin McLernon
Open in new windowTwin Turbo 1UZ in a SupraMatthew Sharpe
Open in new windowExhaust in Melbourne?David Topolovac11
Open in new windowAlternative to Factory Engine Mounts?Aaron Casey23
Open in new windowOil leak from chassisDon Bagnall18
Open in new window3L Non Turbo (JZZ31) 200km ServiceJeremy Tennant
Open in new windowPCV old and newPeter Nitschke
Open in new windowV8 HeadersAndrew Ferres
Open in new windowMetalic particles in oilDon Bagnall
Open in new windowTT cutting out?Ben Evans
Open in new windowOver heating ???Peter Nitschke34
Open in new windowHow often should throttle body be cleaned?Nathan Triplett11
Open in new windowRemoving O2 sensorAnish Varsani
Open in new windowGood mechanic in vic???Steve Anthony De Vos
Open in new windowEverything polish now (pics)Joshua Rowland37
Open in new windowExhaust systemDon Bagnall19
Open in new windowV160 on a 1UZ.... done!Don Bagnall
Open in new windowEngine Idle problem!Jeremy Tennant10
Open in new windowFoul smell in cabinDon Bagnall
Open in new windowV8 fan question Don Bagnall32
Open in new windowBored of this blower now.Matt Dellamalva
Open in new windowBFI 3 Question Michael Keen30
Open in new windowMore exhaust stuffMike Bradberry
Open in new windowURGENT.... NEED HELPTim Spicer
Open in new windowOverflow hoseRobert Kotomski
Open in new window400RPM IdleCihan Aday
Open in new windowV8 Soarer exhaust questionsMark Paddick42
Open in new windowAFTERMARKET CAMS ON THE V8Mark Paddick36
Open in new windowHelp, power steering dramasDaniel Drury
Open in new windowLoud Ticking SoundDan McColl14
Open in new windowChuff and PSHHHH noises!Peter Nitschke
Open in new windowHELP!! Car stallingMark Paddick
Open in new windowSuspect Tuning Tyler Durden10
Open in new windowO2 sensor part numberNeil Griffiths
Open in new windowExhaust Purchase Michael Bagshaw10
Open in new windowPredator Intercooler/Radiator KitBen Socratous
Open in new windowMore starting woesEd Fitzgerald
Open in new windowBloody compliance peopleMike Bradberry10
Open in new windowFuel control systemAvin Luther
Open in new windowTiming Belt StrengthAvin Luther31
Open in new windowTime for me to show off my new V8 exhaust (UZZ10)Andrew Ferres21
Open in new windowSupercharger manifoldDamien Smith13
Open in new windowLexus SC300/1JZ swapped - boosting problem.Chris Morgan
Open in new windowSpit & PolishJustin Cook25
Open in new windowDrop In Boost???Shane McInnes15
Open in new windowV8 missingAdam Foster
Open in new windowCar rampsAlan Carter12
Open in new windowManual Conversion.David Vaughan33
Open in new windowHeader tank - a dodgy piece of design work.Dave Hart20
Open in new windowHelP!!! My Power Steering broke!Hayley Rafati
Open in new windowFuel Filter DilemmasDave Storrie13
Open in new windowDiff gasketMustafa Akgul
Open in new windowWasher motorCihan Aday
Open in new windowBFI 3 Question Mike Biggs
Open in new windowHelp, every soarer problem known to man Dan McColl10
Open in new windowHelp end a stupid discussionSteve Nolan23
Open in new windowExhaust optionsBenny Gammelmark
Open in new windowVery touchy throttle?Brett Cashmore10
Open in new windowV8 driving like a tractor upto 3000RPMCharlie Hooper
Open in new windowUZZ31 driving like a dogPhil Gibson46
Open in new windowEPA and cops sent me a Christmas presentMorgan Cross35
Open in new windowTT V8Luke Middleton
Open in new windowElectronic Supercharger?????????????Geordie Smith16
Open in new windowIdle ProblemCihan Aday
Open in new windowIm stupid!!!!John Le
Open in new windowInstalling headersNeil Griffiths
Open in new windowReplacing water pump for a 1UZ-FE (v8)David Phan15
Open in new windowV8 Radiator Fan Hydraulic Oil Pump Don Bagnall
Open in new windowAliminum RadiatorsJoshua Rowland
Open in new windowNEED MECHANICEdwin Burton
Open in new windowFuel filler problem (a different kind of problem perhaps)Avin Luther22
Open in new windowPlease Help - changing beltsFreeman Tang17
Open in new windowUnichip intsalllKurt Harrison
Open in new windowInjector ticking louder then normalBrandon Stevens
Open in new windowDisconnecting fuel pump ecu??Chris Davey
Open in new windowCar SurgingCharlie Hooper10
Open in new windowRemoving sound deadening in bonnet. bad?Tom McGruther10
Open in new window vibration under accelerationCihan Aday
Open in new windowCatsBlaine Hanson
Open in new windowCorrect engine idle speedPeter Nitschke16
Open in new windowHelp! killed the spark plug cover screw tread.arGHPeter Ha15
Open in new windowX-pipe vs 1 Big Cat ExhaustPeter Nitschke22
Open in new window"I'm gonna ask the Audience on this one" --- What is a "JASMA"? ...Toan Nguyen11
Open in new windowCoolant ProblemJohn Le
Open in new windowPassenger air bagMike Bradberry
Open in new windowCatalytic Converter and Alternator not Charing battery signs.Eldin Didic
Open in new windowEthanol.Johnny James98
Open in new windowHelp needed urgentEmanuel Spinola
Open in new windowOil filling questionBrian Laws32
Open in new windowV8 Upgrade path?David Vaughan76
Open in new windowStrange whining noiseTim Appleton
Open in new windowWhy am I blowing Catalytic Converters all the time?Miles Baker17
Open in new windowA 10 psi supercharger questionJeff Wilkins13
Open in new windowDriver's door handle problemTom Kneebone
Open in new windowV8 mod list - expected percentage power increaseMike Beck25
Open in new windowRadiator Top Tank ReplacementThomas Mulraney
Open in new window1/4 Mile Time Improvements from a Shift KitBrendan Hax
Open in new windowPost Pics of your engine detailing/engine bay...Morgan Cross26
Open in new windowCleaning engine block??Shane Ilich
Open in new windowFlames out of exhaustJames Harris17
Open in new windowUnder accelerator pedal?Ben Evans
Open in new windowFuel empty error/bongDon Bagnall
Open in new windowOil aint oils?Mustafa Akgul51
Open in new window"Engine system fault"Mike Biggs
Open in new windowFuel Surge.Damien Smith16
Open in new window$$$Mechanics Suck Arse$$$Heath Fox41
Open in new windowMorons!!Adam Lonergan12
Open in new windowHelp leaking fuel Avin Luther
Open in new windowCold air intake. Which one, i found about 6?Thomas Mulraney21
Open in new windowSoarer Specialist in Melbourne???Matthew Norton23
Open in new windowUnichip Info Dan McColl27
Open in new windowMarkwell toyota, milduraDrew Hiron10
Open in new windowMelbourne city lexusRyan Rankovic
Open in new windowCrash restoration -A few questionsDan McColl
Open in new windowV8 blowing smoke - what are options and prices?Miles Baker16
Open in new windowIts been along timeBenjamin Burgess
Open in new windowV8 tappetsDave Hart
Open in new windowStrange noise?Vinh Bui
Open in new windowFuel saver Benny Gammelmark19
Open in new windowBest place to service in perth?Rod Rinaldi
Open in new windowPCV valve prop, no startDan McColl
Open in new windowBFI for 97 Soarer... Thoughts.Thomas Mulraney19
Open in new windowLeft hand engine pipe.Avin Luther
Open in new windowDyno tuning a NON forced induction carCarl Johnson28
Open in new window180km/h throttle cut outBlake Roeleven27
Open in new windowIgnition barrel KAPUTDaniel Lee
Open in new windowHow good are the Timing belts on the V8 ?Alex Milne13
Open in new windowRattling Clanking Noise ???Avin Luther
Open in new windowBattery Problems - Soarer TTGraham Dollisson30
Open in new windowJerky car and BP ultimate fuelJosh Rafton27
Open in new windowSpark PlugsThomas Mulraney
Open in new windowLight ticking sound under moderate load (V8)David Janiec28
Open in new windowTRD FiltersLiam Swan
Open in new windowInteresting experienceLiam Swan16
Open in new windowMobil 1 10w-30??Mike Triggs15
Open in new windowRough at Cold StartClayton Webb
Open in new windowGood Mechanics and service centers on the Gold coast ?Lew Radbourn15
Open in new windowWhere's the fuel filter?Dan McColl
Open in new windowV8 Thermostat Prices - MelbourneDelan Peiris26
Open in new windowFreaky friday and my radiatorPeter Nitschke19
Open in new windowV8's Pre May 95 and after May 95 whats the difference???????Andrew Ferres10
Open in new windowFew odd questions, my 1jz manual soarer..Ben Evans13
Open in new windowV8 surging.Andrew Ferres
Open in new windowNeeded urgently: actuator for Cs superchargerStuart McPherson
Open in new windowFuel Pump DisconnectionEmanuel Spinola
Open in new windowV8 Fuel Filter ReplacementMichael Whitman
Open in new windowEngine stalls while drivingDon Bagnall
Open in new windowProblem to noteEd Fitzgerald
Open in new windowIdle problem!Shane McInnes
Open in new windowBFI QuestionsMike Triggs
Open in new windowAnyone know a good, trustworthy mechanic in adelaide?Kris Antczak
Open in new windowPower Steering Fluid "Disappearing"Steve Patterson40
Open in new windowWashin Pod FilterMike Triggs
Open in new windowDoor locksDon Bagnall
Open in new windowNo power steering - HELP!Michael Banazis18
Open in new windowO/d switch and ect/pwr switchKevin la Terra29
Open in new windowGAS Conversion?Peter Nitschke
Open in new windowInteresting ROOTs supercharger setup - intercooledMarshall Hughes32
Open in new windowNew Exhaust System!! *with pics!*Semyon Denenberg20
Open in new windowQuestion regarding the timing belt tensionerAndrew Ferres
Open in new windowCan't get the key out of the ignitionBrett Moloney26
Open in new windowSpark PlugsNeil Griffiths
Open in new windowURGENT help required - PLEASE READ & TRY TO HELP - engine misses no...Dan McColl25
Open in new windowIgnitionEmanuel Spinola12
Open in new windowQuick exhaust question (UZZ31)Don Bagnall
Open in new windowInstallation of timming belt in V8Jeff Harper
Open in new windowThe car still idles rich/stall at times when warmed...HELPAndrew Ferres18
Open in new windowSoarer Mechanic in BrisbaneLew Radbourn13
Open in new windowHELP!!! Exhaust caught fire!!! UZZ31 Don Bagnall17
Open in new windowPower Steering "vibration" felt in steering wheelRoger Costello
Open in new windowCoolantPeter Nitschke16
Open in new windowThoughts on Ethanol Fuel...Robert Carlyon19
Open in new windowPLEASE HELP!!!- Exhaust Problems (i think)Paul Irwin28
Open in new windowSteering box fluid leak Bruce Shepherd
Open in new windowMotor PartsAndrew Ferres
Open in new windowWow - car goes hard when coldPeter Nitschke16
Open in new windowNo Keys help neededSteve Gorman
Open in new windowNew Soarer Owner is in desperate need of advice. Jerky CarMiles Baker17
Open in new windowWhat's better? BFI or pod?Richard Tan24
Open in new windowSome Weird Noises coming from car Benny Gammelmark11
Open in new windowRadiator leakJustin Camilleri
Open in new windowFlushingAnish Varsani
Open in new windowGetting my hands dirtyJeff Hogan25
Open in new windowKnock Sensor LocationNeil Griffiths
Open in new windowWarning Light on Instrument ClusterBenny Gammelmark16
Open in new windowPower Window DriveDon Bagnall
Open in new windowIgnition timing and ECT computerBenny Gammelmark62
Open in new windowSo what oil and filter should I use for service?Roger Costello
Open in new window1UZFE sluggish,Benny Gammelmark50
Open in new windowCoolant Level Sensor WarningRoger Costello
Open in new windowURGENT: How to install door locking mechanism!!!!!!!!!!!!!!!!!Jeff Hogan
Open in new windowSmall Metal Plate Moving near serpintine belt???Nathan Grech
Open in new windowModified sumpTim Appleton
Open in new windowLeaking, High Pressure, Power Steering HoseBernie Juckers
Open in new windowParts and part numbers for service?Andrew Ferres
Open in new windowHigh idle in the mornings..is this a good or bad thing?Shane Moffitt12
Open in new windowSoarer-CobraTim Eacott
Open in new windowOil disposal?Ian Johnston22
