  Soarer Central * Mechanical - Common * Question regarding the timing belt tensioner Previous Previous    Next Next
Anthony Wah Day
Soarer GT V8
Monday, September 05, 2005 - 10:52 pm, by:  Anthony Wah Day (Naastee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
After you have compressed it and place the allen key in, bolted the tensioner on how do you get the allen key out given the amount of pressure we need to compress the tensioner, or should we forget the allen key idea and bolt tensioner on with the shaft extended
UZZ32 V8 Soarer #183
Tuesday, September 06, 2005 - 06:16 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can easily pull the allen key out after you install the tensioner. If its tight use some pliers to pull it out. I don't think you could install the tensioner while its extended.
Freeman Tang
JZZ30 GT-TL
Tuesday, September 06, 2005 - 11:28 pm, by:  Freeman Tang (Cobra_man) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if u tighten up those 2 bolts bit by bit, u know, half turn on this one and then half turn on the other, it will be fine. Just dont do up 1 bolt until it's tight then do the other... I have done it that way on my last 2 TT's, it is fine, just take ur time. It's easier than the allen key idea.
Andrew Ferres
Cressida V8
Wednesday, September 07, 2005 - 11:46 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've done it like that a couple of times.
But this was before I knew what it was.
Motors had a hard life since I did it, so its obviously not caused any damage... yet...
