  Soarer Central * Mechanical - Common * Power Steering main bearing. Previous Previous    Next Next
Jon Millerchip
Reg: 01-2006
Wednesday, January 17, 2007 - 08:52 am, by:  Jon Millerchip (Chip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi just wondering if anyone could tell me do you have to replace the seals in the power steering pump if I want to change the main bearing? I have noticed that my power steering pump has a really loud bearing noise coming from it, but works fine and it has no leaks (since I replaced one of the O-rings on the top hose about a year back). Any info would be great. Thanks.
Darryn Dewar
Gisborne
UZZ30 Soarer
Wednesday, January 17, 2007 - 08:59 am, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
While I'm not sure on the answer, it probably makes sense to do them anyway while you've got the pump off and in bits.
Jon Millerchip
Reg: 01-2006
Wednesday, January 17, 2007 - 12:45 pm, by:  Jon Millerchip (Chip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yer I think I will, turns out toyota only wants $50 for the seal kit which I thought was pretty good.
