  Soarer Central * Mechanical - Common * Need pic ASAP - Stock BOV Previous Previous    Next Next
Chris Hilton
Reg: 12-2006
Monday, May 28, 2007 - 10:18 pm, by:  Chris Hilton (Tetsuo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi ALl,
need help ASAP.
Can anyone link/ post me a picture of the stock 1jz TT blow off valve. I think ive lost a small T piece
Thanks
Chris
Chris Hilton
Reg: 12-2006
Monday, May 28, 2007 - 11:05 pm, by:  Chris Hilton (Tetsuo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok so i lost the T piece and now its just the rail connected to the 'lower' outlet of the stock BOV. is there any repecussions about not have the top outlet connected to what would be the T-piece?
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Tuesday, May 29, 2007 - 08:05 am, by:  Brian Timms (Turbo_brian) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I believe the top piece actually provides the up and down action of the BOV piston, which releases or holds the air in.... (Someone correct me if I am wrong).
The top bit needs to be somehow T-pieced back to the intake plenum to get it's boost/vacuum.
B.
Chris Hilton
Reg: 12-2006
Tuesday, May 29, 2007 - 08:21 am, by:  Chris Hilton (Tetsuo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks brian. Ill go to Bunnings today and see if i can get one
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Tuesday, May 29, 2007 - 08:31 am, by:  Brian Timms (Turbo_brian) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If your just after T-piece, supercheap or any other car bits place will have them for about $2.50
B.
Chris Hilton
Reg: 12-2006
Tuesday, May 29, 2007 - 09:34 am, by:  Chris Hilton (Tetsuo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers brian! ill head up there on my lunch break. Currently haha there is this little umm metallic shifting? sound when i accelerate since the T-piece isnt in.
Was cruisin along and i hear this noise so weird im like hmm what tha.
Back to the old stocky :-( its to quiet might get the plumback turbosmart one eventually just dont know where to plumback into! seems a long way for the tubing to go from left side of engine to intercooler piping.
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Tuesday, May 29, 2007 - 10:20 am, by:  Brian Timms (Turbo_brian) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The stock BOV has a plumb back pipe, this is where the turbosmart would plumb back to...
B.
Chris Hilton
Reg: 12-2006
Tuesday, May 29, 2007 - 03:10 pm, by:  Chris Hilton (Tetsuo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
can some please tell me on the stock BOV, is the black face of the small cylinder attached to the BOV facing the BOV or away from it? the other side is a 'leather' colour
one side passes air, the air is very restriced.
Thanks
Chris
Chris Hilton
Reg: 12-2006
Tuesday, May 29, 2007 - 03:37 pm, by:  Chris Hilton (Tetsuo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://soarercentral.com/sc-forum/messages/51875/72699.html
same as this thread labeled 'GONE'... is black side the upper part or lower?
Kyle Wathen
GTTL
Reg: 02-2007
Tuesday, May 29, 2007 - 09:29 pm, by:  Kyle Wathen (Cspot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That little hose with the the one-way valve has been removed from my car too, i have no idea why Like this...
http://soarercentral.com/sc-forum/messages/51875/113483.html
Jeff Bedsor
Reg: 10-2006
Wednesday, May 30, 2007 - 07:44 am, by:  Jeff Bedsor (Jeff_bedsor) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They usually break when you take them of, mine did so I left it of and made no difference at all.
Chris Hilton
Reg: 12-2006
Wednesday, May 30, 2007 - 07:57 am, by:  Chris Hilton (Tetsuo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kyle thanks for the link mate. exactly what i was after.
Ill replace with hose later today.
