  Soarer Central * Mechanical - Common * Rough at Cold Start Previous Previous    Next Next
Clayton Webb
Thursday, September 29, 2005 - 12:52 pm, by:  Clayton Webb (Clackers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Whenever I start my V8 from cold it splutters for about 2 seconds and it's driving me crazy!!! Could it be a fuel,back pressure or ECU problem?? Would an ECU reset help?? ANy help will be greatly appreciated.
Jason Kingsmill
UZZ31 Soarer V8
Thursday, September 29, 2005 - 01:34 pm, by:  Jason Kingsmill (Jason_k) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ECU reset won't hurt, that's for sure.
Could be some leaky injectors dribbling some fuel while engine is off...running too rich for a few seconds??
Or, the start of fuel pump ECU problems possibly?
Andrew Ferres
Cressida V8
Thursday, September 29, 2005 - 03:31 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, I've got the same problem.
It comes and goes.
Pretty sure its nothing you've mentioned though, as when its warm, it starts pretty much without touching the key.
Adam Foster
SC400 Limited GT
Thursday, September 29, 2005 - 03:47 pm, by:  Adam Foster (Adam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i think this can also be cause by a hole in the crank case breather hose
Clayton Webb
Friday, September 30, 2005 - 06:03 pm, by:  Clayton Webb (Clackers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just did a reset and the prob is still there. If it was running rich for a few seconds, I would've thought it would blow abit of black smoke as it cleared itself............. The hunt continues!!!
