  Soarer Central * Mechanical - Common * Time for a new engine? Previous Previous    Next Next
Kim Anthony
v8
Friday, September 21, 2007 - 01:03 pm, by:  Kim Anthony (Kma) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well my car is blowing smoke... alot of it
at first i thought it was the turbos... theres nothing in the pipes
there are 2 choices:
1. the valve stem seals, or
2. somthing around the piston
A compression test has come up fine, but i have found metal shaving in the oil
any comments?
Shaun Stephenson
Jzz30 TT & ST162
Friday, September 21, 2007 - 01:34 pm, by:  Shaun Stephenson (Neonasty) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ouch.
Mustafa Akgul
Big Mac
Saturday, September 22, 2007 - 11:30 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kim Anthony wrote on Friday, September 21, 2007 - 01:03 pm:
any comments?
best you take it to a mechanic and get it diagnosed properly. its hard to diagnose things like this unfortunately.
btw just because there is no oil in the pipes doesnt mean its not the turbos.
Wednesday, October 03, 2007 - 11:11 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If the Oil seal is gone in the turbos, you wont get any oil in the intake pips, but it will pile up and just burn nicely in the exhaust badly...
Dont rule out turbos completely.
Wafi Cheebo
Reg: 09-2006
Saturday, October 06, 2007 - 06:58 am, by:  Wafi Cheebo (Wafi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kim,
Is the smoke when accelerating? or on Idle? or after accelerating?
If its on idle I would say its the turbo's they usually go on the 120000km mark, most likely its the turbos.
