Joshua Rao
TryHard WA JZZ30 vvti GT-L & JZZ31
Posts: 477 Reg: 09-2006
| Hi there On my 96 JZZ30 vvti I have the following problem. My O/D and SLIP CONT OFF lights flash while the dash flashes with the message, "SLIP CONT ECT". Also there is now constantly a red light on in the dash on the LHS of the SLIP CONT ECT message. Any idea what I can do, any help is much appreciated. Thanks in advance. |
Joshua Rao
Posts: 487 Reg: 09-2006
| Anyone? |
JunkFilterer South Australia UZZ30 UZZ31
Posts: 9076 Reg: 11-2004
| Not from me, Slip Control isn't common as far as I know. It's for snow jobs. |
Joshua Rao
Posts: 490 Reg: 09-2006
| Ohh crap, thanks anyway pen. |
Andrew Stewart
Tinkerer Queensland GT-T Single Turbo manual
Posts: 87 Reg: 06-2007
| josh, if it is anything like my car, if i loose traction in the wet, i get a little orange car with some "drifty" lines behind it, and if actually being to slide out, i have a message come up on my dash next to the speedo readout saying "Snow". you should have a button underneath the dash to the left hand side of the steering column that says "Slip Cont" and a message will display on the dash "Slip Cont Off". i will take a few pictures tonight and show you what i mean. also if possible can you take a picture of what your dash looks like? |
Mark Lethbridge
Tinkerer Victoria 97 VVT-i JZZ30
Posts: 60 Reg: 07-2006
| Yeah mine works exactly how Andrew explained it. I'm not sure what the red light on the LHS of the message is, if you can take a pic or explain what the light looks like it'll be helpful. |
Joshua Rao
Posts: 491 Reg: 09-2006
| Thanks for your help guys. I'll try to take the picture and post up soon. |
Joshua Rao
DieHard WA JZZ30 vvti GT-L & JZZ31(For Sale)
Posts: 621 Reg: 09-2006
Havent used the car for a few weeks and just started driving it again in the last few days with no problems, done around 300km. Then suddenly the exact same problem started again. Please help me. What to do? |
Mustafa Akgul
Goo Roo NSW ToyoPartsMan
Posts: 1818 Reg: 07-2005
| if it was an error it would be high lighted in RED. |
Joshua Rao
Posts: 623 Reg: 09-2006
| Do you mean the words Muzzy? That red light is always on.Its definately bad news as it starts as soon as the car is on and ever so often it makes a beep sound. The words and "O/D off" and "Slip Cont Off" all flash. Should I stop driving it? |
Scott Casey
Tinkerer nsw soarer v8
Posts: 60 Reg: 02-2008
| ETC there is something going on with the transmission. is the trans shifting ok, not slipping, delay in changing gear?? not being used for a few weeks, could there be a blockage in the trans filter/ strainer, low oil?? |
Joshua Rao
Posts: 628 Reg: 09-2006
| Thanks for reply Scott. Trans shifts fine and no delay in changing gears. When it was used a few weeks ago, the same thing happened. |
Dave Rose
TryHard wa uzz31 v8
Posts: 378 Reg: 03-2007
| Hi Josh try a reset disconnect battery for a while just to see if its an error ? if you want to flush box let me know ....the other thing is that green wire that goes to the diagnostics plug in..i wonder about that ,. |
Joshua Rao
Posts: 634 Reg: 09-2006
| Hiya Dave, tryed disconnecting battery to no avail. You think flushing the box may resolve? Got serviced/fluids replaced in compliance here yeah? So cant be low fluids. Sticker says its not due for a service for another 8 000kms but should I put it in anyway? Local mechanic had no idea what it was. I'll post a pic of that diagnostics plug for all the gurus, I'm sure someone will know what it is. Dave PM sent. Feel bad to drive it as it always showing the error message and beeping at me |
Dave Rose
TryHard wa uzz31 v8
Posts: 379 Reg: 03-2007
| Josh E mail sent...DR |
Bob Eason
Newbie Victoria V8
Posts: 3 Reg: 05-2008
| Does the OD flash repetitively. Dont know about the slip control thing, but the OD light flashes if the front speed sensor on the gearbox fails. The car still feels like it goes into 4th, but there is an issue you an still feel. Replace the front speed sensor and all fixed. |
Dave Rose
TryHard wa uzz31 v8
Posts: 380 Reg: 03-2007
| I think we should forget slip con and call it traction control, Bob ..front speed sensor ?? is there more than one??not clued up on JZZ30VTIs . |
Joshua Rao
Posts: 649 Reg: 09-2006
| So Bob is ther only 1 sensor? |
