  Soarer Central * Mechanical - Common * knockings in the motor. Previous Previous    Next Next
Garth Williams
jamaica
tt
Reg: 09-2008
Friday, October 03, 2008 - 10:17 am, by:  Garth Williams (Markiejam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i think i have some bad news, i was hearing turbo squeling so i was reving the engine to see if its a boost leek or a blown turbo then i started to hear knocking in the motor, checked and realized that i was a lil low on motor oil, my question is though, can i change the bearings without taking the motor out? i did it that way with my vr4 galant before but this one dont seem to have much space under there,can someone with experience in this let me know? i figure if its possible i would need to remove the cross member but dont want to mess up the alignment.
Saturday, October 04, 2008 - 08:14 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I dont think so, from memory you have to remove the engine to get the sump out.
