Saturday, October 25, 2008 - 08:31 pm, by: Ben Kelly(Ace)
Just wondering if anyone can tell me the easiest way to check 1) that an airbag is present and 2) that it is wired up and may work. My airbag warning light doesnt come on but this may be due to being disabled as the cluster display has been worked on a few times it seems.
Sunday, October 26, 2008 - 06:14 am, by: Matt Petersen(Mattmannz)
If you remove the side covers on the steering wheel you will be able to undo some torx screws and actually remove the airbag unit from the wheel.
You will be able to see if it's there and connected via the yellow cabling. You should remove the dash cluster and ensure the light is working and fitted so that the system can notify you if it's working.
