Saturday, August 08, 2009 - 08:52 am, by: Scott Wilkes(Scottywilkes)
Since ive had the car its axle tramped pretty bad, will slide fine, but in a straight line it will tramp bad.
I installed some of Neills rear cradle bushes and this helped slightly, but not much, so i thought it must be the diff flapping around a bit.
So last night i installed some superpro diff pinion mount bushes in there which has stiffened it up nice. But it still tramps, be it not so bad anymore but it still does it enough to worry about my driveline haha.
Im wondering what else it could be? Would worn lateral arm bushes cause it to tramp with movement back and forth?
Also ive stil lgot standard Tems coilovers in the car, they dont have any leaks and seem to work good.
Just trying to weigh up all possiblities, start with the small things and move my way up. Cause its really bloody annoying.
Its a manual JZZ30 as well, mild mods car has kingsprings, 265s in the rear, 235s in the front neils cradle bushes Superpro diff bushes whiteline rear swaybar Exedy HD clutch 3 inch straight through exhaust, highflow cat, LEWS dumps HKS panel filter hitting 12 PSI boost Hybrid FMIC
I just want to nut this out, cause its the only thing letting the car down in my opinion
