Wednesday, August 26, 2009 - 10:21 am, by: Marc Hoffmann(Rushed)
my steering works fine, but makes quite alot of noise at times.
first i thought air, and the fliud lid was not sealing well, so i made a thicker gasket for the lid and that seemed to help.
but soon after i get the whiring back and it just gets louder, last night i checked the fluid after it got to its loudest so far and it looked like a bubble bath in there, fitted the lid tightly and no noise for the rest of the drive home, started car this morning and noise again...
i found the leak this morning, it only leaks oil out when i turn car off (tested a few times), so im assuming its pulling air in when on? how do i fix this is there a gasket or o-ring? or is the problem more sinister?
Wednesday, August 26, 2009 - 02:40 pm, by: Marc Hoffmann(Rushed)
after some research using 2006 posts etc i found that the problem is most likely the o-ring and a new one should be here on friday, ill update then if it worked, heres hopeing
