Austen Menze
Tinkerer WA TT
Posts: 54 Reg: 07-2009
| While I was gapping down my sparkplugs on the weekend I had a peek down the spark plug hole and noticed the pistons had a lot of crap built up on them. Is there anything I can do to clean the carbon off? The blokes over int he US use Seafoam but it doesn't seem to be available over here. Should I worry about it? |
Damian Ware
Goo Roo Victoria UZZ32
Posts: 1133 Reg: 10-2005
| Water injection, steam cleans the engine often results in performance gains as there is no longer carbon creating hot spots in the combustion chamber. |
Austen Menze
Tinkerer WA TT
Posts: 55 Reg: 07-2009
| What's the water injection all about? Anyone's thoughts on this would be appreciated too: http://www.lubemobile.com.au/Content_Common/pg-Fuel-Injection-Carburettor-Ignition-Timing-Belt-Filte r-Service.seo Sounds alright and the price isn't too bad I guess? |
Ryan Rankovic
Goo Roo Victoria Soarer TT GT-TL
Posts: 1406 Reg: 07-2005
| seafoam = subaru upper egnine cleaner there are also other names for it. $20 odd dollars a can from an auto store |
Austen Menze
Tinkerer WA TT
Posts: 56 Reg: 07-2009
| Cheers Ryan. Does the Subaru stuff pump out huge plumes of smoke from your exhaust like the Seafoam does? |
Mike Dobkin
TryHard Essex Soarer TT
Posts: 211 Reg: 10-2008
| I used a fuel system cleaner called BG44K. It really seems to remove carbon deposits and you notice the difference when looking at the pistons through the spark plug hole. Its a bit pricey though. |
Damian Ware
Posts: 1134 Reg: 10-2005
Austen Menze wrote on Wednesday, September 30, 2009 - 07:09 pm:What's the water injection all about?
It is the best way to clean the internals of the engine. Due to the heat produced in the combustion chamber the water vapour becomes steam and it acts like a steam cleaner. |
Austen Menze
Tinkerer WA TT
Posts: 58 Reg: 07-2009
| I'll read up about the water injection and have a look for the bg44k. I've ordered a few cans of the Subaru cleaner so I'll post the results up here when I'm done . What Are normal piston tops meant to look like? Shiny? |
Bernard Smith-Roberts
Tinkerer ACT Soarer V8
Posts: 30 Reg: 08-2008
| old carbie trick was to pour water down the carb at wide open throttle, and watch the carbon and crap shoot out the exhaust. Not recommended, but entertaining on my next door neighbours torana. |
Damian Ware
Posts: 1136 Reg: 10-2005
| Yep it has been used for years and is known to be one of the most effective and cheapest methods. I would suggest injecting fine atomised water is a much better alternative than pouring a bucket of water through the engine. |
Miles Baker
Goo Roo Vic 66 Mustang GT Convertible, 55 Chevy Bel Air, 69 Firebird 455, 69 Nova SS Clone
Posts: 1803 Reg: 08-2005
| Yup, shooting water out of a cheap air degreaser or paint gun into the intake makes for an entertaining exhaust display. Just make sure you rev it up a bit and don't flood it with water. Some folks say a thin stream of boiling water out of the kettle down the carby is even better. |
Austen Menze
Tinkerer WA TT
Posts: 63 Reg: 07-2009
| Sounds interesting, I'll try that after i get my idle problem sorted. Is there a chance this will hydrolock the motor? |
Jeff Bedsor
DieHard QLD TT
Posts: 690 Reg: 10-2006
| You could add it through the intake, that would guarantee you destroy the wheels on your turbo. Water injection is done by injecting a super fine spray into the airflow AFTER the turbos. Some do it before the turbos, but you run the risk of the water droplets wrecking the impellers if you have problems. You dont just spray water in. |
Austen Menze
Tinkerer WA TT
Posts: 64 Reg: 07-2009
| So pull the intercooler pipe off the front of the throttle body and squirt a bit in there? Would one of those water bottle things with the pump handle work alright as I don't have a compressor or anything. |
Andrew Stewart
TryHard Queensland Manual GT-T VVT-i Single Turbo
Posts: 472 Reg: 06-2007
| i got a quote from my local mechanic and he said subi cleaner (same as seafoam) that gets rid of carbon deposits is only 25 bucks. just take off a vacuum line that goes straight into the plenum, turn the car off, let it sit for 5 - 10 minutes then start it up, spray the rest in there, turn it off again for 5 - 10 mins then start it up and take it for a brisk drive. gets rid of all the carbon deposits everywhere |
Damian Ware
Posts: 1138 Reg: 10-2005
| You can suck water in through a vac line which keeps the water well away from the turbos. |
Miles Baker
Posts: 1804 Reg: 08-2005
| See, turbos are nothing but trouble ;) |
Posts: 5489 Reg: 03-2006
Miles Baker wrote on Friday, October 02, 2009 - 11:39 pm:See, turbos are nothing but trouble ;)
ONly against engines triple their size and triple their price in mods ;) |
Austen Menze
Tinkerer WA TT
Posts: 70 Reg: 07-2009
| oooo SNAP! Subi cleaner will be here tomorrow so I'll let you all know.. if that doesn't do a good job I'll try the water injection |
Miles Baker
Posts: 1805 Reg: 08-2005
| Nar, no trouble. I actually do have a motor three times the size of a 1J. It costs less to build and less to modify than a 1J. And I can also put a $4500 supercharger on it and see 650hp at the wheels with only low boost. |
Mike Dobkin
Posts: 212 Reg: 10-2008
| .... and with fuel consumption measured in gallons per mile |
Miles Baker
Posts: 1806 Reg: 08-2005
| Actually it isn't bad. Take it easy and it gets 15 litres per 100. |
Austen Menze
Tinkerer WA TT
Posts: 78 Reg: 07-2009
| WOO subi upper engine cleaner rocked up today.. gonna go stink out the TAFE carpark tonight haha |
Mike Bradberry
Goo Roo Queensland V8 UnLimited
Posts: 1588 Reg: 07-2005
| So I suppose these methods don't send gunk into the cat and block it. Think I'll ask around a bit before I do it. |
Austen Menze
TryHard WA TT
Posts: 108 Reg: 07-2009
| No problem with a "hi flowed" cat Hmm forgot to update this thread..I done the subi cleaner treatment and it blew out STACKS of smoke and the car seemed to breathe a lot easier, quicker smoother revs. I noticed the piston tops are still black and have crud on them so I'll try another can and then the water injection next. The throttle body and plenum and everything inside, however, is SPOTLESS I couldn't believe it! Subi cleaner no |
David Grab
Goo Roo SA T78
Posts: 2003 Reg: 01-2008
| Where did you guys your from, a Subaru dealership? Also depending where you put it you have to change the fluids. Obviously oil needs to be changed for sure after seafoaming it. |
Austen Menze
TryHard WA TT
Posts: 110 Reg: 07-2009
| Yeah I just got it from a subi dealership at 17 bucks a pop. I did it before an oil change even though it mentions nothing about it on the can. I popped off a hose on my intake manifold, shoved the straw up there and started spraying, the stuff foams up as it comes out. |
