  Soarer Central * Mechanical - Common * Whiteline W92930 Engine mount Previous Previous    Next Next
Allan Langford
Reg: 05-2010
Friday, August 26, 2011 - 11:22 am, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone tried these on a the Soarer?
http://www.whiteline.com.au/Plus/product_detail.php?part_number=W92930
Shane Haverkamp
soarer TT
Reg: 10-2007
Friday, August 26, 2011 - 06:38 pm, by:  Shane Haverkamp (Havabeer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
link doesnt work
Allan Langford
Reg: 05-2010
Saturday, August 27, 2011 - 01:33 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just search for the part number W92930
David Henderson
Nsw
Reg: 08-2007
Monday, August 29, 2011 - 07:23 am, by:  David Henderson (Hendo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How much $? supra ones are solid as and fairly cheap, cant remember the exact price but $60 each rings a bell
Allan Langford
Reg: 05-2010
Monday, August 29, 2011 - 11:33 am, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
supra ones also fall to bits...
list is $300ish for the whiteline ones, i'll get a trade price...
Victoria (The Nazi State)
Pretty Red Thing and The Black Beast
Monday, August 29, 2011 - 08:07 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Woo, NVH city. If you don't mind every noise and vibration of the engine being sent throughout the car then these will be great.
Allan Langford
Reg: 05-2010
Monday, August 29, 2011 - 08:28 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dan, you have tried them?
Considering how smooth the 1UZ is I think the NVH would be minimal and they are not a solid mount and poly still has good vibration absorbency... I would not mind hearing a little more V8 in the cabin, I think the 275/35R18 tires all round will still drown out any engine NVH anyway!
Nathan Richardson
N.T.
UZZ32 #445 (V8 Supercherged 5Speed. 291RWKW)
Monday, August 29, 2011 - 08:51 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I might be interested in these.
Reducing the amount the engine moves would be a good thing in my case and I think I could live with the additional NVH.
Dave Rose
wa
uzz31 v8
Tuesday, August 30, 2011 - 11:12 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
One of the reasons the v8 is so smooth ,is the engine mounts are oil filled.The engine is floating on compressed oil. I understand the extra power with a s/c does strain them ,how about new Toyota mounts and a stabilizer bar like on the Toyota 1mz-fe v6.
Tuesday, August 30, 2011 - 06:16 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have experienced similar ones on a Turbo soarer. Fine for a track hack, you certainly wouldn't want them on a long trip.
I'd suggest an engine torque damper. This will take the torque load off the engine mounts, but still retain the soft cushy mounts for nice NVH.
Allan Langford
Reg: 05-2010
Tuesday, August 30, 2011 - 07:33 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave: Oil does not compress, the rubber flex's around it
Dan: link to similar ones?
Matt Newman
soarer tt
Reg: 11-2007
Tuesday, August 30, 2011 - 08:15 pm, by:  Matt Newman (Soarersrock) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Allan oil does compress however it is normally so little that it is regarded as non compressible. but in a large hydraulic system it has to be allowed for.
cheers matt
E36 Coupe
Tuesday, August 30, 2011 - 08:25 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How much heat can these polyurethane mounts handle?
Wont the exhaust heat from the exhaust manifolds above the engine mount position effect the material?
Allan Langford
Reg: 05-2010
Wednesday, August 31, 2011 - 07:31 am, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matt: yes but not in a toyota engine mount :-)
mike: good point, but probably the same as rubber.
Matt Newman
soarer tt
Reg: 11-2007
Wednesday, August 31, 2011 - 03:45 pm, by:  Matt Newman (Soarersrock) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
good point Allan but just thought that it should be made clear. i can only imagine that the poly will handle higher temps than the rubber however a heat shield as found in the factory mounts would be cheep prevention.
Wednesday, August 31, 2011 - 08:00 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't have a link, but google Kazama mounts.
Allan Langford
Reg: 05-2010
Wednesday, August 31, 2011 - 10:05 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
dan: with the two mounting points they would be approximatly twice as stiff as the whiteline ones...
Thursday, September 01, 2011 - 10:29 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No Worries, Allan. Just providing my input of my experience with similar mounts.
If you feel that these are for you then go for it mate.
Damon Cornish
Reg: 03-2009
Thursday, April 10, 2014 - 07:40 pm, by:  Damon Cornish (Boz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Old thread I know but I brought a set of these for my uzz30 project. At this stage I haven't used them as the test fit didn't.
To use them either they will require modification or the upper alloy engine mounts will need to be made wider. I'm trying the Megan ones first.
