  Soarer Central * Mechanical - Common * HELP. my tt wont fire Previous Previous    Next Next
Adrain Parsons
y
Saturday, September 03, 2011 - 08:49 pm, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi, my TT wont fire, it winds over but wont start, ive tested the battery, the fuel ecu( did the by pass on it) checked the timing and belt, checked the fuel line and pressure, there all good.
So what could it be?
Matthew Weaver
Reg: 01-2010
Saturday, September 03, 2011 - 09:39 pm, by:  Matthew Weaver (Spinna) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
check all fuses mate
Saturday, September 03, 2011 - 09:40 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How much fuel in tank ?>
Immobiliser Issue ?
How old are the SPark plugs ?
Igniter ?
Ecu died , try swapping in another ?
What mods has the car got ?
Adrain Parsons
y
Saturday, September 03, 2011 - 10:48 pm, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
fuses all good, tank 60litres, immobiliser good, spark plugs 30000km but thats maybe 6 years ago, i dont drive the soarer much,
Whats the Igniter? where is it located?
Dont have a spare ecu.
Mods are fmic, safc2, 440 injectors, bfi, all this was done years ago and didnt have a problem untill today.
ideas?
what about the crank angle sensor?w here is it? lol
thanks
Victoria (The Nazi State)
Pretty Red Thing and The Black Beast
Sunday, September 04, 2011 - 12:54 am, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Try running diagnostics. Let the car tell you whats wrong.
Adrain Parsons
y
Sunday, September 04, 2011 - 02:48 pm, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i read about the diagnostics but it doesnt seem to say how you run it, any tips?
Sunday, September 04, 2011 - 05:49 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
On the main page, under the Diagnostics topic.
Linky for those too lazy to go to the main page and click one button.
http://soarercentral.com/sc-forum/messages/1113/1113.html?1150010852
Adrian McGuire
soarer 2.5 turbo
Reg: 12-2010
Monday, September 05, 2011 - 08:08 am, by:  Adrian McGuire (Adro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
did you sort it?
Adrain Parsons
y
Tuesday, September 06, 2011 - 11:43 am, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ran the diagnostics, no fault codes came up, said its all good.
Tuesday, September 06, 2011 - 10:51 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Blocked FUel pickup ? Or even FUel pump dead?
Adrain Parsons
y
Wednesday, September 07, 2011 - 08:02 am, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
all fuel is good.
Adrian McGuire
soarer 2.5 turbo
Reg: 12-2010
Wednesday, September 07, 2011 - 08:08 am, by:  Adrian McGuire (Adro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
double check the EFI fuse in the engine bay fuse box. Where is QLD are you?
Adrain Parsons
y
Wednesday, September 07, 2011 - 11:22 am, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Im in Mareeba near cairns, you ?
Adrain Parsons
y
Thursday, September 08, 2011 - 05:50 pm, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dont worry everyone, its the motor, 5 out 0f the 6 pistons only has 25 psi.
Adrian McGuire
soarer 2.5 turbo
Reg: 12-2010
Thursday, September 08, 2011 - 05:54 pm, by:  Adrian McGuire (Adro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How did you check it? Was it using much oil? When was the last time it started?
Adrain Parsons
y
Thursday, September 08, 2011 - 06:17 pm, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
a mechainic has it, he checked the compression., wasnt using any oil, it stop as the car was doing 150km/h. and didnt start after that.
Thursday, September 08, 2011 - 09:53 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
LOL . Stopped @ 150km/h ...
Flat out and popped it huh ? FOrgot to mention that at the start it seems ,
Adrain Parsons wrote on Saturday, September 03, 2011 - 08:49 pm:
At least you know now , nothing worse than still searching for gremlins . Good luck with the rebuild :-)
Adrain Parsons
y
Friday, September 09, 2011 - 05:05 pm, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
no rebuild. might just sell it off.
Ali Saeed
Friday, September 09, 2011 - 05:13 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just drop in a 2jz
Adrain Parsons
y
Friday, September 09, 2011 - 05:33 pm, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
not sure if i realy want to worry about the hassles of doing it, How much woould a replacement engine cost me?
Saturday, September 10, 2011 - 10:16 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Replacement 1j with lowish km's , less than 1200 .
2jz , under 2200 .
Shane Haverkamp
soarer TT
Reg: 10-2007
Sunday, September 11, 2011 - 09:03 am, by:  Shane Haverkamp (Havabeer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there's long motors in the forsale section for $500 or less. i'm even selling mine for like $300ish
