  Soarer Central * Mechanical - Common * FUEL level misreading - confused seeking advice Previous Previous    Next Next
Open in new windowArchive through September 23, 2011Allan Langford25
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Sunday, September 25, 2011 - 11:32 am, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Guys,
I've done a full fuel clean up - so it must be the dash ..
If my thinking is right this is probably caused by old caps. I will look into a replacement dash.
Greg Wyllie
Reg: 11-2010
Wednesday, September 28, 2011 - 08:52 pm, by:  Greg Wyllie (Bearshead) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I had a problem with my fuel gauge reading when I used E85, actually ran out of fuel on the M2 at night with 2 kids in the car.......I've used only 95 or 98 since and the gauge is accurate as can be.
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Monday, October 17, 2011 - 06:11 pm, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
Sorry for the delay but I had to be sure.
after further research I consulted my brother who has borrow the car a few days before the issue started/.
Turns out he put "at least" 30 L of e85 (got might have even been blended e10 cos he is cheap as This screwed everything up ... after doing all the fills/metho/swaps and constantly topping up it turns out that I was at 60+ litres and this caused my gauge to go mental as well.
Anyway - I put a jerry can in the car and have driven it for 300+ks now.
Is sitting on 23 L's now and is behaving normally. (has since 40L)
I am now confident the issue is resolved. Thanks for all you help!
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Friday, October 28, 2011 - 06:51 pm, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
still good. It's back to normal. Issue was most certainly scum bag brother putting in cheap fuel
Saturday, October 29, 2011 - 02:49 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can you sell him off? :-)
Jol Alexander
UZZ31 V8 (no mods)
Reg: 07-2009
Saturday, October 29, 2011 - 07:45 pm, by:  Jol Alexander (Courage) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nah his my brother - kinda like a tattoo you're stuck with.
