Thursday, January 12, 2012 - 12:44 pm, by: Ben Lipman(Ben12a)
Hey, does anyone know what the cooling system gaskets are made of? Specifically the one running out of the back of the water pump and under the turbos on a 1JZ?
I have been to Toyota and there are no replacement gaskets in Australia. There are some on order from Japan, but I have been waiting for three weeks and still no word.
I am figuring I might just make my own from a blank gasket, but can't remember if they are rubber, metal or cork (Pretty certain they are not cork). The turbo ones are all metal, but I am thinking the water ones were rubber from memory. I would just pull it off and have a look, but it is in a prick of a spot. I want to do the job in one hit as the car supposedly was going to Morpowa this week, and I would hate for it to not be able to go because it is apart.
Thursday, January 12, 2012 - 01:08 pm, by: David Henderson(Hendo)
Hey Ben
They are a steel gasket with a raised hump around them, designed to crush.
The gasket behind the water pump comes with the pump. The upper water pump housing has a similar crush washer which doesnt come with the water pump.
I reused the top pump to head gasket with a smear if black toyota FIPG each side last week and it hasn't leaked yet.
I am however suss on the interference fit o ring seal between pump and upper housing, it has never leaked but it just seemd a little bit funny putting it on
Thursday, January 12, 2012 - 02:22 pm, by: Ben Lipman(Ben12a)
dammit! I suspected as much. Mine started leaking after my turbo swap. I don't remember undoing the pipe at all, and it is in a prick of a spot to tighten with the turbo back in.
I might try loosening it off and smearing some gasket goo/engine silicone sealant around it before retightening.
Thursday, January 12, 2012 - 05:11 pm, by: David Henderson(Hendo)
from memory the pipe will flex a bit, and its not too bad to get too, helps having the fan/shroud/airbox off too.
it may be preferable to take the old one out if you can get it, make a new gasket (with the sides cut out of the bolt holes so you can slip it in) and smear a thin layer of goo both sides of the gasket.
Can't recommend toyota FPIG enough, it's a cut above all other sealants ive used and it doesn't set in the tube
Thursday, January 12, 2012 - 08:37 pm, by: Ben Lipman(Ben12a)
Yeah, I read up on it on the web. I might buy some just to have in the toolbox. Can you get it in Australia? $30 shipping for a tube costing $13 is ridiculous.
For some reason the leak is not there any more? I got it hot, revved it, held it on WOT but it doesn't leak any more.
There are numerous leaks in my second hand ally radiator though...
