  Soarer Central * Mechanical - Common * Bloody compliance people Previous Previous    Next Next
Mike Bradberry
Thursday, January 12, 2006 - 08:43 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
When the compliance people do their changes I wish they would do a job worthy of the car. I specifically refer to the changing ( or adding ) the new cat. Mine has had an extra cat added into the single pipe where there used to be a resonator. The originals have been left up front. So I have a total of three cats. To rectify this ( my choice ) means removing the two fronts, making a 3" pipe where the 2 1/4" single is and adding a 3" high flow cat and $750 later I will ( I hope ) have a little extra performance.
Avin Luther
vic
Soarer uzz31 Limited
Thursday, January 12, 2006 - 11:55 pm, by:  Avin Luther (Lex_luther) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just remove the one that they added.
the toyota ones are meant to be good.
Phil Gibson
'94 black/black UZZ31
Friday, January 13, 2006 - 02:27 am, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What Avin said - i would leave the original cats alone and get rid of the one they added - 2 cats are better than 1 *and* its not gonna cost you $750 :-)
Mike Bradberry
Friday, January 13, 2006 - 07:44 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I thought the added cat made the system legal for Australia. If that is not the case why would it have been fitted? I love the idea of not having to do all that work, but no-one is going to do it if it is not legal.
Mark Paddick
Soarer UZZ31
Friday, January 13, 2006 - 10:07 am, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just do what Avin said and give the old standard cats a clean. Then you can say you fitted new factory cats. That's all the powers-that-be require; fitment of new cats. How can they tell the originals weren't new x months ago?
JunkFilterer
Friday, January 13, 2006 - 10:18 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If it has already been complianced, who cares?
Avin Luther
vic
Friday, January 13, 2006 - 11:13 am, by:  Avin Luther (Lex_luther) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
exactly, It aint gonna be checked for compliance again, and if it does fit flanges for the new cat you are removing, and you can bolt it back in if need be. and dont feel bad for the environment, i know of soarers without any cats!
Mike Bradberry
Friday, January 13, 2006 - 11:25 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The decision has been made. I will simply fit the 3" pipe with resonator and leave the original cats up front. Thanks for the feedback guys. Total cost about $200.00.
Anish Varsani
V8 UZZ30
Friday, January 13, 2006 - 03:23 pm, by:  Anish Varsani (Yomama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you plan on an exhaust upgrade, now is the time to do it or you'll pay twice. Why not go a cat back exhaust. Will cost you a bit more but you'll be removing the restrictive stock mufflers. Should come in around $400-450.
Mike Bradberry
Friday, January 13, 2006 - 03:43 pm, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah, Anish I have already done that shortly after purchase. Cheers.
