I have fuel leaking from under the car - the area where the fuel main hose and fuel return tube come through the floor on the drivers side of the car near the differential. The bolts are all tight, the fuel seems to be coming from above the vent case cushion. Any ideas?
There are two aluminium washers that seal the actual fuel line, no problem there. All the fittings on the bottom of the tank have a locating pin, the hole for the locating pin is open into the fuel tank. There is a rubber washer that seals the fuel line fitting to the outside of the tank, this was perished and caused the leak. Replacement aluminium washers will be easy, the rubber washer / gasket will be harder to find.
Friday, April 17, 2015 - 11:23 am, by: Ilya Ali(Ilya_ali)
Jan Hi, have the same problem on my car but it is just on the main side. The return side looks to be OK, where did you end up getting the rubber washer/gasket?
Friday, April 17, 2015 - 07:11 pm, by: Ilya Ali(Ilya_ali)
Just spent the afternoon looking for both washer at part shops here, no luck. I'll get the parts from Amayama.com tonight, Partsouq.com do not have them.
