  Soarer Central * Mechanical - Common * Knocking sound from rear Previous Previous    Next Next
Darren Bak
qld
Reg: 02-2013
Wednesday, December 31, 2014 - 12:27 pm, by:  Darren Bak (Dmb169) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi there another problem has developed... getting a loud knocking sound from the rear hard to pinpoint which side but sounds like the left, but the right also has a sound but not the knocking more metal hitting metal, might just be the dirt protector thing sits behind rotor.
anyway the sound is constant with the rate of speed slower i go slower it knocks, go faster knocks faster. so far i have:
tapped on some parts with a mallet cant hear anything loose
bounced the four corners of the car to see if it was suspension but couldn't hear anything loose
tried moving the wheels around when jacked up but they seem pretty solid
could loose brake pads make a loud enough knocking sound, i just used the pads that came with the rotors, so im not sure if there good or bad, but the shims have all fallen off them ...
if you had a similar problem can u let me know as i dont think the mechanic is open until next week.
Darren Bak
qld
Reg: 02-2013
Wednesday, December 31, 2014 - 12:52 pm, by:  Darren Bak (Dmb169) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
found a video of what it sounds like, but my knocking also happens when driving not just braking.
https://www.youtube.com/watch?v=p2jx7AwvfLY
Darren Bak
qld
Reg: 02-2013
Wednesday, December 31, 2014 - 03:31 pm, by:  Darren Bak (Dmb169) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
have a short video of a noise which may be what im hearing
http://youtu.be/SzyviCz-oKg seems like a pretty bad place to be making a knocking sound though :-(
Daniel Bonnor
soarer uuz31
Reg: 06-2014
Thursday, January 01, 2015 - 12:37 am, by:  Daniel Bonnor (Majorlunacy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
where in qld are you if in seq i could swing by and help out if you like ?
Darren Bak
qld
Reg: 02-2013
Friday, January 02, 2015 - 06:39 pm, by:  Darren Bak (Dmb169) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks for offer but you are far away from where i am.
drove the car for a while today with no knocking however there is noise coming from the rear. i jacked the rear left up and spun the wheel it gets caught up at one point then moves easily again.
Daniel Bonnor
soarer uuz31
Reg: 06-2014
Saturday, January 03, 2015 - 12:23 am, by:  Daniel Bonnor (Majorlunacy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
that's ok looking at your video one thing would be to count the knocks for one turn of the wheel and if 5 or 6 i'd be looking at the cv's on the half shafts one way to tell is to jack the car up like in the video but use a second jack under the the suspension to load it up so the half shaft is parallel and see if noise is gone or quieter if so cv's
Darren Bak
qld
Reg: 02-2013
Sunday, January 04, 2015 - 07:03 pm, by:  Darren Bak (Dmb169) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok will try that, have driven the car around and no knocking but still sounds like something scraping or catching from the rear left, or im just paranoid about any noise i hear.. currently have an old rotor on the rear left to see if makes a difference.
Darren Bak
qld
Reg: 02-2013
Saturday, January 10, 2015 - 04:32 pm, by:  Darren Bak (Dmb169) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
been driving for about a week now with no drama then this..
https://www.youtube.com/watch?v=wBRBwQQsnRM&feature=youtu.be
Friday, January 16, 2015 - 01:32 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any chance a broken tooth in the diff?
Darren Bak
qld
Reg: 02-2013
Friday, January 16, 2015 - 02:00 pm, by:  Darren Bak (Dmb169) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yep its the diff, mechanic says its the bearings are stuffed... thinks about 1-1.2k to replace them.
so no more car for now :-(
Robert Day
V8 & 1J VVTI
Reg: 01-2007
Friday, January 16, 2015 - 02:27 pm, by:  Robert Day (Lexsmaz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tricky one to diagnose & its a very slow noise & maybe slower than wheel speed by the looks of it too ?( going by outside movement ) if it is the diff, just throw a second hand one in it, you can pick up a single spinner Non LSD for about $150 ..
Blake Gloyn
manawatu
soarer JZZ30 TT
Sunday, January 18, 2015 - 04:22 pm, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah bud, don't pay 1.2K to get diff bearings replaced!
