Monday, January 16, 2006 - 10:54 am, by: Neil Griffiths(Aussiesc)
Go to Repco..Ask for the Multi Fit single wire sensor that has the 22mm bolt head on it.. You then cut your sensor wire and join to the Repco one.. Retails at about $90 each
Here is Genuine No 89465-28200 ( Repco may not be able to match that No) Only Genuine will show it..
Don Bagnall Moderator New Zealand 1991 UZZ30 GT4.0 V8
Monday, January 16, 2006 - 05:45 pm, by: Pree Vengetas(Pree)
Neil does the 92 V8 main 02 sensor have only one wire coming out of it cause mine has melted and i can only find one wire sticking out of the wiring loom. The main 02 sensor has only one wire in the connection, is that right?
Neil Griffiths Trader NSW I have MORE Soarers than Hayden :-)
