  Soarer Central * Mechanical - Common * Alternative to Factory Engine Mounts? Previous Previous    Next Next
Adam Brown
Soarer TT Manual
Monday, January 16, 2006 - 09:33 pm, by:  Adam Brown (82ajb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys.
I think the axle tramp i experienced at the drags the other night caused an engine mount to crack (or at least the one i can see well).
I know that the soarer ones are around $280, and the supra ones are a bit cheaper and stiffer. Is there any other alternative any cheaper than the supra one?
1991 UZZ30 GT4.0 V8
Monday, January 16, 2006 - 09:36 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No. (other than 2nd.hand)
I have MORE Soarers than Hayden :-)
Monday, January 16, 2006 - 09:50 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can go MORE Expensive..And you will NEVER break it :-)
Mustafa Akgul
JZZ30-GTTL
Monday, January 16, 2006 - 09:54 pm, by:  Mustafa Akgul (Muzzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
most soarer engine mounts are broken anyways even the ones that look ok.pay particular attention if your engine seems like its on a slant .as Rob hayden found out was very expensive to repair with a cracked sump as the engine was sitting on power steering lines.
i have supra ones and they are great
Graham Dollisson
GT-TL
Monday, January 16, 2006 - 10:12 pm, by:  Graham Dollisson (Alloyvee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here is a recent thread on engine mounts with reference to Kazama mounts!!
http://soarercentral.com/sc-forum/messages/126/30418.html
Matthew Tai
Monday, January 16, 2006 - 11:06 pm, by:  Matthew Tai (Matttai) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
why is it better to have stiffer? would it not be better to have new stock mounts as they have more a cushion effect?
Ben Vandie
JZA80 Supra
Tuesday, January 17, 2006 - 11:21 am, by:  Ben Vandie (Vandie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
go for a solid mount
Benjamin Burgess
Toyota Soarer GT-TL
Tuesday, January 17, 2006 - 11:54 am, by:  Benjamin Burgess (Jampac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew Tai wrote on Monday, January 16, 2006 - 11:06 pm:
So engine doesn't move around as much. You'd be surprised how much it moves under the loud pedal, especially if its not standard power.
Adam Brown
Soarer TT Manual
Tuesday, January 17, 2006 - 03:57 pm, by:  Adam Brown (82ajb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks guys. I ordered some supra mounts today. Same as soarer ones but much stiffer. Will this help the problem i'm having with axle tramp?
Matthew Oswald
Tuesday, January 17, 2006 - 05:50 pm, by:  Matthew Oswald (Matt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Im not sure if this problem your having with axle tramp has alot to do with your engine mounts?
Im no expert but i always thought stuffed shock absobers were the cause of it.
I may very well be wrong, but i think thats more likely the cause?
Adam Brown
Soarer TT Manual
Monday, January 23, 2006 - 09:29 pm, by:  Adam Brown (82ajb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well, i got some supra mounts and changed them this afternoon. To my surprise, it actually went well, no great difficulties! Also to my surprise, i discovered that both mounts had completely split in two! It may not have had much to do with axle tramp, but it certainly wouldn't help!
The original next to the supra mount
Split original mount
Dave Hart
Not Australia
UZZ32
Monday, January 23, 2006 - 09:36 pm, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Adam, when your Mother/Wife sees what you've done to her bed sheets you'll be in for it.
Adam Brown
Soarer TT Manual
Tuesday, January 24, 2006 - 10:28 am, by:  Adam Brown (82ajb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
When she sees how i got the soarer in my bedroom, she'll be even more pissed!!!
1991 UZZ30 GT4.0 V8
Tuesday, January 24, 2006 - 11:58 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Toan Nguyen
Tuesday, January 24, 2006 - 01:03 pm, by:  Toan Nguyen (Soarer_gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got a set of Kazama engine mounts which I bought locally, but havent put them in yet.
Is there a step by step process to replace engine mounts online?
Adam Brown
Soarer TT Manual
Tuesday, January 24, 2006 - 02:55 pm, by:  Adam Brown (82ajb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It's not hard mate. Just make sure you undo the radiator shroud FIRST!!
Undo the nuts on the top of the mounts, Jack the car up and rest on axle stands. Then undo the nuts on the bottom of the mounts. Using a trolley jack (preferably), some blocks of wood, and a large block to spread the load, jack the engine carefully under the sump. You will need to lift it a fair bit. Pull out the old mounts, insert the new ones and lower the engine slowly, making sure that the bolts go into the holes. Put the nuts on the bottom, lower the car, put the top nuts on. Put the car back together and whala! Took dad and i about 2hrs total.
Now, does anyone have a spare radiator fan shroud...
Justin McLernon
UZZ32
Reg: 01-2006
Thursday, February 02, 2006 - 09:54 pm, by:  Justin McLernon (Zz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
where are the mounts? ie. where exactly are they located in the engine bay?
Ben Evans
"Master Power" Turbo 1J With Xtras
Friday, February 03, 2006 - 12:28 am, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
under the engine? ahahaha
Chris Davey
Corona
Friday, February 03, 2006 - 11:48 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hehe :-)
Adam: good instructions. I don't know why but I had always thought of doing it the harder way by lifting the whole engine out via hoist. Glad I didn't try that :-)
Justin McLernon
UZZ32
Reg: 01-2006
Friday, February 03, 2006 - 08:22 pm, by:  Justin McLernon (Zz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
still looking for those engine mounts...
Friday, February 03, 2006 - 09:11 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Look at the ALLOY Xmember under there..then you will see them bolted to it.
Justin McLernon
UZZ32
Reg: 01-2006
Friday, February 03, 2006 - 09:31 pm, by:  Justin McLernon (Zz32) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers Neil, I'm DIYing them this weekend along with the tranny mount.
BTW for all Soarer/Lexus spare parts I thoroughly recommend James Sloane from Castle Hill Toyota (
jsloane@chtoyota.com.au). Excellent service, great prices and ultra fast delivery.
Aaron Casey
jzz30 gttl
Sunday, February 05, 2006 - 07:32 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeh i just done my mounts on friday.. took me bout 5 mins but i have a bit of experience as apprentice mechanic.. one thing i noticed though is watch the intercooler pipes dont stretch too far when u jack the engine up as u can damage them, mine had a vibration on highway speeds under slight throttle.. i got mine out and they were a 2 piece design too!!! hahahaha but the vibration went so i was happy!! :-) but i found an oil leak from my turbo oil return line and drips onto exhaust so now it blows smoke under acceleration when the exhaust heats up!!! so more stuff 4 me to fix!!
