Can anyone tell me the part numbers for the o-rings for injectors in a 1JZ. The mechanic was going to clean the injectors, but couldn't find a listing on o-rings with fuelmiser or the likes. I need to get a full kit before he will clean them. Once again, i'm sure i came across the info on ALSC under the Injector FAQ.
Your right, you did see it on ALSC. Can't remember the exact number (ask Neil?) but just go into Toyota spare parts and get them from there. I will be getting mine from there, unless anyone can come up with a better solution...
They are for the 360cc stock injector for the soarer. If so, do you think they would be the same for 440cc from a supra, thinking most likely will be different. If so anyone got part numbers for those as well.
Same part Steven. The physical dimensions of the injectors are identical. If anyone gets stuck, go to your local Toyota dealer and ask for ones off a GT4 Celica. Same thing.
