Tuesday, August 02, 2005 - 10:40 pm, by: Tony Trigger
Esteemed advisors -after replacement of water pump by local mechanic this comes on everytime engine is initially started -will go off after engine stopped and then started again . I've tried ecu reset no luck!
Neil Griffiths Moderator 1 x JZZ30,2 x UZZ31,1 x UZZ32,1 x UZZ Track Car,1 x AeroCabin,1 x Crown V8,1 x Celsior
Wednesday, August 03, 2005 - 07:36 am, by: Neil Griffiths
Check the Cam Sensor wire on passengers side of engine.He may have left it hanging and the fan belt has worn through it. OR. Cam sensor on Right side is not plugged in under ignition coil.
Sunday, August 07, 2005 - 09:33 am, by: Tony Trigger
Thanks Neil the wires look ok it's possible he didn't reconnect right side is that a big job? One thing I've noticed is after only 5 minutes engine running if I turn the engine off and start it again the light doesn't come back on -seems to be driving ok !
