  Soarer Central * Mechanical - Common * PS pump fix * Archive through March 27, 2006 Previous Previous    Next Next
Anish Varsani
V8 UZZ30
Tuesday, March 07, 2006 - 09:15 pm, by:  Anish Varsani (Yomama) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Am going to be replacing the seals on my PS pump on the weekend. Had a quick look. Am I correct in saying that two bolts are removed from the front and the other two from the back of the pump to remove it from the vehicle?
Also, is it possible to remove the pump without removing the coolant bubble tank?
Last of all, I've got 8L of Transmax Z. Will using this in the steering system cause the old hose crimp connectors to leak?
Thanks.
Edward Engerer
vic
v8
Tuesday, March 07, 2006 - 11:23 pm, by:  Edward Engerer (Edward) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi my name is edward i own 91 uzz32 has anyone experienced power steering problem? when i turn left or right it seems like the power steering rack has got a dry seal it sounds like a very light grinding sound coming through the steering. the oil level is ok and there is no sign of any hoses damaged. would like some advice please.
Tuesday, March 07, 2006 - 11:35 pm, by:  Don Bagnall (Baggs) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Edward, greetings, and a warm welcomr to ALSC/SC.
I am NOT totally cognisant of your issues, vis a vie the power steering pump, BUT there are MANY members who have had, AND fixed this problem, in the past.
I am sure, that in the fullness of time, one of the 32 owners WILL come to your assistance.
Kind regards,
Phil Gibson
'94 black/black UZZ31
Wednesday, March 08, 2006 - 02:48 am, by:  Phil Gibson (Sciflyer) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anish yes there are 4 bolts, if i remember correctly one of the rear ones was a prick to get at and i actually found it much easier to remove the alternator (simple job) first to get at the bolt.
Also you will need to remove the PS reservior which is attached to the coolant tank mounting so you might as well remove the lot, the extra space comes in handy
UZZ-32 V8 Soarer #138
Wednesday, March 08, 2006 - 11:39 pm, by:  Dan McColl (Hoon) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Edward.
I'm having a problem with mine at the moment.
Occasionally it semi locks up, and almost won't turn left. It makes a high pitched squeal like when you hold the steering hard on full lock.
I've got a feeling it's one of the valves not letting the pressure off the rack on the off side and causing a hydraulic lock.
I haven't had time to investigate properly yet, but have found it's normally ok if I run the steering from one lock to the other before driving off.
I've also noticed it's worse when the temperature is colder.
I'm hoping a flush of the power steering system will fix, or at least help, My problem.
My epc is at home, and I'm not, Can anyone tell me if the steering rack minus the 4ws bits is the same as any other soarer??
Edward Engerer
vic
v8
Saturday, March 11, 2006 - 11:17 pm, by:  Edward Engerer (Edward) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi guys thank you for your respons i have still got problems in my power steering rack in my 32 each time i turn left and right i still get a grinding sound coming from my rack i think; the pump is full with oil to its level mind you the car has not been driven for two years any help would be appreciated thanks guys [edward]
JunkFilterer
Saturday, March 11, 2006 - 11:19 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any chance it has air bubbles in it?
Sunday, March 12, 2006 - 12:49 am, by:  Dan McColl (Hoon) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Edward, Is there any particular times you notice the problem worse or better.
Morning, night, hot, cold, etc???
Edward Engerer
vic
v8
Sunday, March 12, 2006 - 09:30 pm, by:  Edward Engerer (Edward) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i am going to change the oil on wednesday and bleed the system to i will let you know and also the noise thats coming through the steering does it cold and normal temp thanks guys [edward]
Sunday, March 12, 2006 - 09:35 pm, by:  Dan McColl (Hoon) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is also a little bleed nipple on the back of the pump. A right biatch to get to. :-)
Edward Engerer
vic
v8
Sunday, March 12, 2006 - 10:40 pm, by:  Edward Engerer (Edward) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
THANKS DAN I WILL LOOK AT THAT, IN THE EARLY DAYS I USED TO JACK THE FRONT WHEELS TURN ENGINE ON AND STEER LEFT AND RIGHT A FEW TIMES AND CHECK OIL LEVEL
Sunday, March 12, 2006 - 10:47 pm, by:  Dan McColl (Hoon) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Turn off the suspension switch in the boot before jacking.
I need to try and flush mine, too.
JunkFilterer
Sunday, March 12, 2006 - 11:56 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Edward, please avoid using all caps, it looks like you are SHOUTING!
Monday, March 13, 2006 - 12:01 am, by:  Dan McColl (Hoon) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe Ed thinks I'm a bit hard on hearing. :-)
Tamatha Chapman
V8 GT LIMITED
Monday, March 13, 2006 - 03:27 am, by:  Tamatha Chapman (4ltrv8) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you are going to be removing the pump and the alternator. Don't forget to replace 2 copper washers and the clamps. Have had the pump re-sealed and the alternator re-cond about 2 months ago. After several weeks off road still had a leak. Took it to Tilbrooks to put up on the hoist and was shown where it was leaking. Might not have had to pull pump out and re-seal if I had checked all areas first. Just assumed it was the pump as this is the most common of causes. Was told that when removing pump/alternator best to change washers and clamps for these items cannot be reused as they will leak.
Dan McColl wrote on Sunday, March 12, 2006 - 10:47 pm:
Please make sure you follow advice to turn suspension off. If you jack up, makes it unstable. This has been part of reason for car to fall of jacks before getting stands in place. 2nd reason, don't use the pyramid jacks. They buckle under the weight of the V8's.
Monday, March 13, 2006 - 10:07 am, by:  Dan McColl (Hoon) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The pump on the actives is different to the regular V8's.
It's combined with the suspension pump and fitted underneath the alternator.
You just about have to remove the whole front end to pull it out.
Or lift the engine and try and jiggle it out the gap.
Search UZZ 32 or active for more info. :-)
Edward Engerer
vic
v8
Wednesday, March 15, 2006 - 10:54 pm, by:  Edward Engerer (Edward) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi guys whats the best you can get on a [32] how manny klms per litre car is tuned new plugs throttle cleaned was very dirty new leads filter standard wheels and tyres [not for long] freeway and around town driving at a speed limit [now and then]
Edward Engerer
vic
v8
Wednesday, March 15, 2006 - 11:00 pm, by:  Edward Engerer (Edward) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks dan i did not know they were different still got problems with brakes trac modulator
Anish Varsani
V8 UZZ30
Thursday, March 16, 2006 - 12:20 pm, by:  Anish Varsani (Yomama) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Around town, dosn't matter what fuel I use, getting 7.6km/l.
Highway with 91 octane: 8.3km/l
Highway with 95 octane vortex: 8.3km/l
Highway with 98 octane optimax: 9.55km/l (535km on 56L)
Thursday, March 16, 2006 - 07:23 pm, by:  Dan McColl (Hoon) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Do a search on here and also in the archives for tonnes of '32 info.
Also check under the dash and along the steering column, It could be rubbing on something...
Edward Engerer
vic
v8
Thursday, March 16, 2006 - 08:21 pm, by:  Edward Engerer (Edward) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi Anish thanks for the info i heard that in japan, the cars are tuned on high octane
Edward Engerer
vic
v8
Thursday, March 16, 2006 - 08:39 pm, by:  Edward Engerer (Edward) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Dan now that you told me when i drove it this morning i heard the noise coming up through the steering under the dash i might have to check it again.changing the subject,i have to pull out the front shocks, the car is bouncing like hell the only thing that worries me is i hope i got enough room to put the valve in the lower part of the shock,i done the rear plenty of room working fine
Edward Engerer
vic
v8
Monday, March 27, 2006 - 10:42 pm, by:  Edward Engerer (Edward) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys sorry for the late reply regarding power steering noise.I have put new oil in, checked all the hoses there are no leeks anywhere. Its not coming from the steering wheel, but the grinding noise is still there. Next i will check the rack, and if it is, can i buy a reco kit for it? Any idea how much? has anyone done it before?
thanks guys
ted
Edward Engerer
vic
v8
Monday, March 27, 2006 - 11:30 pm, by:  Edward Engerer (Edward) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hello again can someone help me here please i would like to know if my car was one of the early hundreds or late hundreds manufactured in 91 here are some numbers, mdl uzz32 acpzk, eng iuzfe 3968cc, frme uzz32 0001344, trans axlt a341e ao1a, plnt blt a22.i hope this will be some help for you guys
Tuesday, March 28, 2006 - 12:31 am, by:  Benny Gammelmark (Oldfield) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Edward, I reckon you just need to recondition your PS pump. I had the same problem before doing that.
You can buy a recon kit for about $50 or get a reconditioned one for about $250 (that's what I did).
