  Soarer Central * Mechanical - Common * Rear main seal-TT Previous Previous    Next Next
Dave Storrie
91JZZ30 TT, 95 JZZ30 TT
Reg: 12-2005
Friday, April 14, 2006 - 12:50 pm, by:  Dave Storrie (Casp3r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
I found I have a leaking rear mains seal, and from what I can find so far It is a reasonably simple job, should be able to do it by dropping the gearbox and going through the sump?
Just wondering if anyone else has had it done by toyota, and how much it may cost?
Thanks, dave.
Simon Triantafillou
Soarer Turbo
Friday, April 14, 2006 - 05:50 pm, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Around $80-ish for the seal. Pull the box off, then the flex plate. Remove seal with screwdriver, replace seal and tap in lightly with soft hammer. Replace flex plate and gearbox. Done.
Dave Storrie
Reg: 12-2005
Saturday, April 15, 2006 - 09:16 am, by:  Dave Storrie (Casp3r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for your help mate,
I'm just relieved it isnt an engine out job.
Lew Radbourn
jzz30 ute / uzz30/ 2 X uzz31
Monday, April 17, 2006 - 08:12 am, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave just make sure it is the rear seal and not your cam covers leaking and oil dribbling down the back..
it does happen mate
as that oil will make it look like a rear main seal.
Dave Storrie
91JZZ30 TT For Sale, 95 JZZ30 TT
Reg: 12-2005
Monday, April 17, 2006 - 09:32 am, by:  Dave Storrie (Casp3r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Will do Lew, thanks for the heads up.
See you saturday.
Tayne Riley
Tas
2.5TT
Monday, April 17, 2006 - 11:46 am, by:  Tayne Riley (Maxiain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave
the seal is 90mm ID 110mm OD and 10mm Thick. BSC have these these in stock for $17.00. did our rear main last week.
