  Soarer Central * Mechanical - Common * Fuel Cap Door Release Previous Previous    Next Next
Robin Giles
Limited UZZ31
Thursday, May 18, 2006 - 07:11 pm, by:  Robin Giles (Rob) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My fuel cap door wont open. The button under the dash is in the right spot because the boot release works. I've tried the "pull this" cord in the boot ...... nothing. I'm getting a click like the solenoid is working but it just not releasing ie the catch is stuck. How can I get it open? short of leavering it with a screw driver. Couldn't se a way of getting in through the back.
JunkFilterer
Thursday, May 18, 2006 - 09:41 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Robin, you will probably need to lever it open, use a small flat screwdriver well wrapped in a bit of rag to protect the paint. Have someone pull the release cable in the boot while you do this. Once open, you can investigate why it isn't opening easily.
This is on the assumption that the catch has released, but is just sticking a little bit. If it won't open easily with a lever, then you have a major problem.
Robin Giles
Limited UZZ31
Thursday, May 18, 2006 - 10:36 pm, by:  Robin Giles (Rob) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter got it open without too much trouble the little spring had come off and was stopping it from opening and the spring was still there. I put it back together and all is fine now I just need to fill it up.
JunkFilterer
Thursday, May 18, 2006 - 11:24 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good that you had a win. Filling it up I can't help you with :-)
Robin Giles
Limited UZZ31
Friday, May 19, 2006 - 09:17 am, by:  Robin Giles (Rob) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pity, are you working on that as an additional feature for the forum?
Andreas Niaouris
W.A.
Friday, May 19, 2006 - 09:37 am, by:  Andreas Niaouris (Andreasn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
he he, you've got my vote Robin, great idea!!
