  Soarer Central * Mechanical - Common * Constant fuel smell :-( help Previous Previous    Next Next
Pavan Ratra
Reg: 05-2006
Wednesday, June 21, 2006 - 10:51 am, by:  Pavan Ratra (Aap_ka_sahil) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
everytime i get into the car from a long period of inactivity (ie a few hours or so) i can smell petrol inside the car... and after a long drive, when i get out of the car, i can smell fuel jst outside the car... i dont know whats wrong.. could it be a split in the fuel line?
Ashley Leach
UZZ31 V8 GT Limited
Wednesday, June 21, 2006 - 09:37 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got a similar problem. Seems to happen only occasionally. I can smell it in the boot, but it's stronger inside the car.
Anyone got any ideas?
Darryn Dewar
Gisborne
UZZ30 Soarer
Thursday, June 22, 2006 - 06:19 am, by:  Darryn Dewar (Mrphreak) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://www.planetsoarer.com/petrolsmell/petrolsmell.htm
Rik Garth
Victoria / Queensland
Reg: 05-2006
Saturday, July 01, 2006 - 05:15 pm, by:  Rik Garth (Nakedfaerie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Also check the inlet. I had dribbles down the side of the car and a petrol smell then I got the inlet siliconed in and its all fixed now.
Pavan Ratra
Reg: 05-2006
Tuesday, July 04, 2006 - 01:02 pm, by:  Pavan Ratra (Aap_ka_sahil) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey guys, thanks for all your help :-)
it turned out to be a split in the catalytic converter... i got it fixed, and now no fuel smell :-)
Fred Azzarello
UZZ31 4.0GT Limited (V8)
Reg: 05-2006
Tuesday, October 31, 2006 - 07:54 am, by:  Fred Azzarello (Sc400iinetnetau) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Scott’s note on Planet Soarer is right, the petrol leak is coming from the vent pipe on the petrol tank. But cutting this hose during compliance is not required. Only the retarded compliance companies that don’t know how to modify the petrol intake of a Soarer will cut this pipe. Take your Soarer to Tony Brown at Adrenalin on the Gold Coast (07 5591 2444) to fix the petrol leak permanently. Or call around to your local Soarer specialist and they will fix it for you. Cost is about $150.
Ashley Leach
UZZ31 V8 GT Limited
Tuesday, October 31, 2006 - 01:35 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Or you can just do it yourself... 5mins and about $10
Lynden Phillips
Soarer UZZ31
Reg: 05-2006
Friday, November 03, 2006 - 08:22 am, by:  Lynden Phillips (Malicia) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dad had a fuel smell on his 32, turned out the fuel cap had a crack in it, replaced and no more fuel smell.
Phil Gibson
'94 black/black UZZ31
Friday, November 03, 2006 - 02:25 pm, by:  Phil Gibson (Sciflyer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Number 1 culprit for fuel smells from what ive seen is the fking stupid nozzle restrictor put in as part of compliance - the design of the ones that are brazed in such as mine is poor and if the brazing is even slightly dodgy vapours and even raw fuel can leak out from between it and the original pipe
Either replace the whole inlet pipe or seal the outside properly with metal putty and leak test
Another example of compliance rules making a car worse than it was before
