  Soarer Central * Mechanical - Common * Piston and Conrod Previous Previous    Next Next
JunkFilterer
Tuesday, August 15, 2006 - 01:16 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This is what happens if you suck water in your intake. From a Hilux.
Tuesday, August 15, 2006 - 01:41 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I take it the con rod bent when trying to compress the water, thus fracturing the piston?
V8 Ltd manual
Tuesday, August 15, 2006 - 01:59 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Noe Schitt-Sherlock
Emanage is tha good.
Tuesday, August 15, 2006 - 03:32 pm, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've seen a 1JZ soarer with a blown head gasket at the auctions, the guy gets in, starts it and puts his foot straight to the floor. The thing coughs and splutters all the way to redline then starts missing heavily and stalls. Meanwhile people 5 metres away are covering their faces because of the steam..
Moral of the story, 1JZ = tough
