  Soarer Central * Mechanical - Common * Computer Engine Simulation - 1jz 2jz 1uz Previous Previous    Next Next
Matthew Oswald
Thursday, August 17, 2006 - 08:00 pm, by:  Matthew Oswald (Matt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am doing a mechanical engineering project on combustion modelling, and I am using a expensive piece of program called "Ricardo Wave" which is a computation fluid dynamics program that simulates engines.
Now, what I would like to do is to simulater a couple of toyota engines... 1jz 2jz and 1uz and then once the base model is done, you can change all differnt sorts of things, like manifold geometries, valve lift profiles, pretty much any mod, you can see the effect it has on torque and power output before without having to spend the big bucks.
The first plan of attack was to model the 1uz, as it could probably have the most info about it, plus there is no turbo to simulate.
So if anyone has a spare one lying around, or has any measurements to give me, please feel free to share the love and see what we can come up with.
Michael James Madigan
JZZ30 GTT-L
Friday, August 18, 2006 - 01:38 pm, by:  Michael James Madigan (Micksoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That's a great idea Matthew. Can anyone help this guy out?
Andrew Ferres
Cressida V8
Wednesday, August 23, 2006 - 12:45 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jump on the lextreme forums.
There are already datafiles on there for a certain program mapping the entire motor and its characteristics
