Damian Ware wrote on Saturday, March 24, 2007 - 08:41 am:A laser realignment will fix the skipping misread and allow you to use burnt disks. Not only can you then use burnt disks you will also have a much high tolerance to skipping.
All CD lasers go out of alignment over time, I think you are just lucky that your particular stacker will play this burnt disk. More importantly it is likely that other cd stackers will not play this particular disk as the each laser over time has distorted differently.
Just remember there are different versions of the laser mechanism and all react differently and have all aged differently as well.
