  Soarer Central * ICE - In Car Entertainment * ICE Chat * Factory Changer not working at all. Previous Previous    Next Next
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Thursday, August 16, 2007 - 08:02 am, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I can't seem to get my factory changer to work. If I put a disc in the cartridge it will load the cartridge and start to go through the discs but it never seems to load the disc, no matter which slot I have it in. As for the display it read "ERR" and flashes.
Is it not reading the disc? Is there a simple fix or should I be tearing this thing apart?
Thanks,
Dale
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Friday, August 17, 2007 - 02:01 am, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone?
I've got a road trip this weekend.
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Friday, August 17, 2007 - 05:31 am, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Here is a vid of what it is doing
http://s167.photobucket.com/albums/u137/XtraXZX2/?action=view&current=MOV01739.flv
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Friday, August 17, 2007 - 05:50 am, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
New story, disc is loading but getting a Err message.
I figured out after a few tries that it goes thru all the discs first then loads it.
But now I'm getting a "ERR" on the in dash screen. What now.
I know I'm talking to myself but I'm in Canada, are our CD's different?
Damian Ware
UZZ32
Thursday, August 23, 2007 - 01:15 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
CD stacker are a common problem.
If you do a search you will find heaps of threads about it.
You can also find information here.
http://www.planetsoarer.com/mark/index.htm
I am unaware of anyone in Canada that can repair your stacker for you you could always send it overseas to myself or Luke Gomer.
I suggest you consider replacing the stereo with a aftermarket system.
Graham Dollisson
GTTL , Morris Marina, P76 V8 Super, P76 6cyl Deluxe
Thursday, August 23, 2007 - 01:35 pm, by:  Graham Dollisson (Alloyvee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Try pushing the reset button, on the inside back of the loading area.
