  Soarer Central * ICE - In Car Entertainment * ICE Chat * FM expander installer Previous Previous    Next Next
Sidd Venkatesan
Thursday, October 13, 2005 - 10:18 pm, by:  Sidd Venkatesan (Siddvenkatesan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys;
Ive got a japanese spec eclipse headunit which works perfectly, except for the radio, which is on japanese bands only. Is there anyone reccomended who can install the FM band expander in Sydney? Preferrable close to CBD would be good.
Thanks
Sidd
Sam Schreck
vvt-i JZZ31
Thursday, October 13, 2005 - 10:24 pm, by:  Sam Schreck (Schreck300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Send it to Mark Paddick in Canberra. Express post, and you'll have it back in a couple of days. He's da man.
Sidd Venkatesan
Thursday, October 13, 2005 - 10:44 pm, by:  Sidd Venkatesan (Siddvenkatesan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How does he fix the actual unit? Do you get the right numbers showing up on the unit?
Sam Schreck
vvt-i JZZ31
Thursday, October 13, 2005 - 10:51 pm, by:  Sam Schreck (Schreck300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1. Mark will install a band expander which will allow you to receive the stations here.
2.I don't believe so. Never with a Jap unit. You'd have to buy a local head unit for that.
Sidd Venkatesan
Thursday, October 13, 2005 - 10:54 pm, by:  Sidd Venkatesan (Siddvenkatesan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
bugger - I was hoping to just get it done in Sydney itself. The sad thing is that there is already an expander in the car, but for some reason just doesnt work....
Mark Paddick
Soarer UZZ31
Thursday, October 13, 2005 - 10:59 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Band expanders are simple to fit. Check out Reepas' site for instructions.
Sidd Venkatesan
Thursday, October 13, 2005 - 11:03 pm, by:  Sidd Venkatesan (Siddvenkatesan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think reepa is still updating his site. Also, from memory, the instructions he had were for a V8 (different location to TT)
Mark Paddick
Soarer UZZ31
Friday, October 14, 2005 - 09:48 am, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Different location but exactly the same principal.
Connect antenna to expander, expander to radio antenna input and expander power wire to antenna power from radio. Simple.
Black/Black JZZ30 VVTi
Friday, October 14, 2005 - 10:37 am, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Do the stock head units need two FM expanders? I've got one but reception is rubbish.
Mark Paddick
Soarer UZZ31
Friday, October 14, 2005 - 11:39 am, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It is debateable whether fitting the second expander will improve things because the diversity circuit in the tuner will see the carrier from the first expander and assume there is a good signal and never switch to the second one.
A proper conversion is the way to do it but that's not ready....yet.
A better quality expander may help.
Sidd Venkatesan
Friday, October 14, 2005 - 03:16 pm, by:  Sidd Venkatesan (Siddvenkatesan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In that case, are there any wiring pin diagrams for what the antenna wire is? Im very tempted to just poke around and see if I can get it working.
Sidd Venkatesan
Friday, October 14, 2005 - 03:29 pm, by:  Sidd Venkatesan (Siddvenkatesan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Responding to myself here, but is this the correct wiring for our cars?
http://www.installdr.com/walkoffhomerun/installdr/installdr/Harnesses/Toyota-Wiring.pdf
Mark Paddick
Soarer UZZ31
Friday, October 14, 2005 - 04:24 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The antenna power wire is always attached to the antenna cables but you could just use any Acc power (cig lighter).
Sidd Venkatesan
Friday, October 14, 2005 - 04:50 pm, by:  Sidd Venkatesan (Siddvenkatesan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry, but what colour is the antenna wire? Just to make sure I am splicing into the right one.
Sidd Venkatesan
Sunday, October 16, 2005 - 10:38 pm, by:  Sidd Venkatesan (Siddvenkatesan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just tried adding the FM band expander, and just cant get it to work at all. So........ can any one recommend ANYONE who can fit the converters ? I know it should be a very simple fix, but at this point, just want my radio working!
Chris Cheung
Thursday, November 24, 2005 - 08:47 pm, by:  Chris Cheung (Obscurusc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sidd... it's the blue cable from the eclipse headunit. Remote antenna turnon. that'll give the fm expander power. Get some bullet connectors from jaycar, crimp it onto the end of the fm expander power, plug in done.
If it wants a ground cable too, black one from the headunit.
David Topolovac
Saturday, December 03, 2005 - 11:15 pm, by:  David Topolovac (Topola) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone knows where to get one expander and how mutch are they?
Rob Andreacchio
UZZ31 V8 / JZZ30 TT
Reg: 01-2005
Saturday, December 03, 2005 - 11:38 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
autobarn, jb hfi, strathfield, any other audio place. how mutch? i would say around $20-25.
David Topolovac
Sunday, December 04, 2005 - 11:52 am, by:  David Topolovac (Topola) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Rob...
