Friday, February 01, 2008 - 11:18 pm, by: David Tra(Bookie)
hey guys, i recently purchased 6.5 speakers which i would like to fit into my rear parcel shelf. I have no idea what i am doing. I need help, can someone assist me please with a how to guide please?
Friday, February 01, 2008 - 11:30 pm, by: Chris Harbord(Chrisco)
Here you go http://www.clublexus.com/forums/showthread.php?t=109384 Although you don't have to remove any of the rear panels as you can just carefully pull the shelf out once the rear seats are out, just don't bend it too much or it will break
Brian Timms DieHard New South Wales TT Soarer Goodness.
Monday, February 04, 2008 - 11:49 pm, by: Phil Stuart(Ericdog)
I agree with brian, its a pretty simply task once you remove the rear seat. I upgraded the stock sub in the parcel shelf for a more modern 10", and added a 12" in an infinite baffle enclosure in the boot, run both in parallel, and it kicks quite nicely. Oh, and you surely find out if you have any rattles in the rear once getting some low frequency audio running !
The 6.5's are an easy fit also. I have done the same.
