  Soarer Central * ICE - In Car Entertainment * ICE Chat * Brackets for CD Changer Previous Previous    Next Next
Gary Nimmo
Tuesday, November 08, 2005 - 09:04 am, by:  Gary Nimmo (Gazzasore) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can someone please post some pics for me
I bought an original CD stacker a while back
But im not sure how it fits in the boot
Where does the amp go etc
& I dont have any brackets at all
So I will need to make some up
Thanks in advance
Ian Johnston
UZZ30 GT 4.0
Tuesday, November 08, 2005 - 12:41 pm, by:  Ian Johnston (Ted) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It all fits in the RH well in the boot.
It would be easier if you can get the original brackets.Amp mounts under the stacker, stacker mounts to the amp brackets via its own brackets, which then bolt to the side of the boot.
Mark Paddick
Soarer UZZ31
Tuesday, November 08, 2005 - 03:41 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Which model car?
EMV and non-EMV cars mount the amps in different spots (still on the stacker brackets)
I possibly have spares for both types.
Gary Nimmo
Tuesday, November 08, 2005 - 11:50 pm, by:  Gary Nimmo (Gazzasore) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
She's a 91 V8 Mark with EMV
Mark Paddick
Soarer UZZ31
Wednesday, November 09, 2005 - 11:17 am, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No problem. I should have a set of those brackets....
Gary Nimmo
Wednesday, November 09, 2005 - 11:54 am, by:  Gary Nimmo (Gazzasore) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Great Mark How much do you want for them
Can you email me please Mark
gaznim@tpg.com.au
