  Soarer Central * ICE - In Car Entertainment * ICE Chat * Help! my stacker won;t play cd's! Previous Previous    Next Next
Andrew Daziani
SC400 GT Limited
Reg: 08-2008
Thursday, August 21, 2008 - 02:08 am, by:  Andrew Daziani (Dazaj001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I loaded my stacker with cds (genuine copies) and the stereo recognises that there are cds in there, but they won't play...does anyone know why?
Andrew Stewart
Manual GT-T VVT-i Single Turbo
Reg: 06-2007
Thursday, August 21, 2008 - 05:59 am, by:  Andrew Stewart (Daboom) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
like all old pioneer stacker units, the label of the CD needs to face to the tray, so the "read side" is the side you see. the opposite to normal cd players
Andrew Daziani
SC400 GT Limited
Reg: 08-2008
Thursday, August 21, 2008 - 10:35 am, by:  Andrew Daziani (Dazaj001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have tried putting the cd's both ways up but still nothing...once loaded should the cd's play automatically?
Wess McManus
v8
Thursday, August 21, 2008 - 12:12 pm, by:  Wess McManus (Bar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
label side up.
They should play automatically once the c.d button pressed,though if theres a few cd 's in there you have to be patient.
Is it emv equipped? do you get an error code?
Thursday, August 21, 2008 - 05:09 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew Daziani wrote on Thursday, August 21, 2008 - 02:08 am:
(genuine copies)
HAHAHHAHAHAHA
Copies of Originals work well :-)
Andrew Daziani
SC400 GT Limited
Reg: 08-2008
Thursday, August 21, 2008 - 10:30 pm, by:  Andrew Daziani (Dazaj001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wess McManus wrote on Thursday, August 21, 2008 - 12:12 pm:
Only when I put the cd's in the wrong way up! If i load five cd's it recognises that it has five cds and when I select a cd I can see and hear the stacker loading the disc but I don't get any sound!
Christian Zimmer
Reg: 09-2006
Thursday, August 21, 2008 - 10:33 pm, by:  Christian Zimmer (Zimmi) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I would try getting some speakers
Sorry, had to do it
Andrew Stewart
Reg: 06-2007
Friday, August 22, 2008 - 08:32 am, by:  Andrew Stewart (Daboom) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Andrew; the next thing i would suggest would be to track someone down who also has a stacker and swap it with yours to see if it is a faulty stacker or headunit. i would also suggest pulling out your headunit just to make sure one of the cables aren't out a little. if you listen to the radio or cassette, do you get sound then?
Andrew Daziani
SC400 GT Limited
Reg: 08-2008
Friday, August 22, 2008 - 03:10 pm, by:  Andrew Daziani (Dazaj001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes I get sound with radio and cassette...could it possibly be a dirty or faulty laser?
Scott Gates
Friday, August 22, 2008 - 03:15 pm, by:  Scott Gates (Scotty_001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah it sounds like a laser problem. Should see if you can get another stacker to see if it works then.
