  Soarer Central * ICE - In Car Entertainment * ICE Chat * Spare tyre compartment Previous Previous    Next Next
Nathan Hlad
soarer jzz30 tt
Reg: 09-2008
Saturday, January 31, 2009 - 01:14 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
anyone removed the spare tyre compartment under the boot ??
how did you do everything ?
Adrain Parsons
JZZ30 tt
Saturday, January 31, 2009 - 08:20 am, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
some people do it, but what do you do if you get a flat?
Nathan Hlad
soarer jzz30 tt
Reg: 09-2008
Saturday, January 31, 2009 - 08:23 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ive got no spare anyway or even a jack. hahaha
Ben Lipman
Soarer TT manual
Saturday, January 31, 2009 - 09:25 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am considering it for the track car. Primarily so I can get the big jack under the diff with out first lifting a side with the little jack.
And because I am a shocking tinkerer.
I was thinking of cutting it out and welding in some thin steel sheet, possibly with some bracing in case this area is stressed.
Adrain Parsons
JZZ30 tt
Sunday, February 01, 2009 - 10:31 am, by:  Adrain Parsons (Ace1975) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nathan i hope you dont get a flat in the middle of the NT.
David Grab
T78
Reg: 01-2008
Sunday, February 01, 2009 - 01:20 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a spare tyre and also tyre weld as i would be too lazy to change a tyre in the middle of nowhere. Question for you guys is how do you guys remove your spare? As in i want to get rid of it as i have tyre weld and shed a bit of weight but then the floor plank isnt sitting on anything and will jump around. Also if you put something heavy in the middle it might fall through or break the plank? So how do i get rid of the spare yet have rigidity for shopping and stuff?
Dave Rose
wa
uzz31 v8
Sunday, February 01, 2009 - 09:15 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben I was thinking is it wise to put the full weight of the car on the diff? ? as its on rubber mounts and never has to take the weight on it?.
But then its only for a short time.
Ben Lipman
Soarer TT manual
Sunday, February 01, 2009 - 09:36 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is very little weight in the rear of my car, but yes it is just long enough to get axle stands under there.
David Goldthorpe
UZZ31 GT-L
Reg: 11-2007
Sunday, February 01, 2009 - 11:03 pm, by:  David Goldthorpe (Sprocket82) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
David Grab wrote on Sunday, February 01, 2009 - 01:20 pm:
The "plank" is actually fairly sturdy. I put my shopping in there all the time with no spare tyre underneath (took it out to make room for amps).
David Grab
T78
Reg: 01-2008
Monday, February 02, 2009 - 11:31 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeahi can feel its pretty thick but say you put something weighing 29kg in the middle of the plank over the wheel well and it would bend. Worst part is when i can the wheel out, no weight on the plank but in the boot it would jump around and make a clunking noise which gets annoying fast.
