  Soarer Central * ICE - In Car Entertainment * ICE Chat * Dynamat: Who's done it? Previous Previous    Next Next
David Grab
T78
Reg: 01-2008
Wednesday, May 27, 2009 - 02:33 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So story goes that my car is pretty much stripped out at present, well actually for the last few months. Anyway i dont remember everything rattling so much especially the bootlid. Now i dont know ifi its just because there is no trim in the car and the boot so i was thinking whilst everything is pretty much out ill dynmat the whole interior. Seems the sub is shaking the rear plate and the boot lid. I was just wondering if anyones done it and mainly what did you do about the fuel tank? I was thinking of making a MDF cover sheet for the fuel tank but dont really want to add weight to the car, not that much anyway. Did you guys just leave the fuel tank as it was? Id be interested to see/hear what people have done to their cars with dynamat.
-Dave-
Michael Marchant
Soarer UZZ32 V8 finished in Zymol goodness!
Wednesday, May 27, 2009 - 02:45 pm, by:  Michael Marchant (Mavric) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dave, I have dynamat'ed (dynamat and dynaliner in some places) all the major areas of my car (except the roof) and it made a major difference to the sound quality of my stereo. It also eliminated all my annoying rattles and reduced the amount of exhaust noise and heat entering the car through the floor. Doing your actual number plates is a must if your running a sub. Your base will also be a lot tighter and more defined if you do the boot lid and boot floor.
I have done a fair few cars now so if you have any questions just shoot.
You can see the pictures of my install at
http://picasaweb.google.com.au/home
David Grab
T78
Reg: 01-2008
Wednesday, May 27, 2009 - 03:04 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah Michael ive used its before and know its the bomb. From memory i had stuff all rattle when all the trim was in place but i know bass was leaking out so if i do it SPL will increase and so will quality. However normally if i do a boot i do all 4 sides and the boot lid but with our cars there is no solid structure to put dynamat infront of the fuel tank. Did you just stick it on the trim piece that sits infront of the fuel tank?
Ps. your link just shows a baby in a tiger costume hahah
Michael Marchant
Wednesday, May 27, 2009 - 03:11 pm, by:  Michael Marchant (Mavric) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
haha sorry mate, my bad. Correct link below
http://picasaweb.google.com.au/mavric23
I didn't do anything with the fuel tank. I found that after I finished with the boot floor/sides and lid nothing else was required and I was very happy with the sound.
David Grab
T78
Reg: 01-2008
Wednesday, May 27, 2009 - 08:46 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah im just worried as it should be an enclosed area that you dynamat that the front area of the fuel tank will cause leakage of SPL. But i just realised i might stick it on the back of the trim overing the fuel tank. That should work better than nothing at all. Did you just do the boot or the doors arwell? Any idea how much i might need? Im thinking 36sqf should do the job.
Michael Marchant
Wednesday, May 27, 2009 - 09:25 pm, by:  Michael Marchant (Mavric) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Did you see my pictures? I did the inner and outer door skin, the boot, the floor and behind the back seat and in the foot wells.
From memory I think I used two bulk packs and a couple of extra sheets as well as dynaliner and dynaxorb (behind the drivers and in the sub box).
David Grab
T78
Reg: 01-2008
Wednesday, May 27, 2009 - 09:44 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah im just about to get to the pics, my net has been the last few days as it keeps dropping out every 2 mins arghhh! haha will ahve a good look at them once they load. Thank Michael
Janitha Jayawardena
Soarer V8 Limited Edition
Reg: 05-2009
Sunday, June 07, 2009 - 06:52 pm, by:  Janitha Jayawardena (Drjani) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Michael, approx how much dynamat material did you use?
Do u reckon this would cover it?
http://cgi.ebay.com.au/DYNAMAT-Xtreme-Bulk-Pack-10455-9X-Sheets-36SqFt-3-35m2_W0QQitemZ180362729099Q QcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item29fe74d68b&_trksid=p3286.c0.m14&_trkparms=65%3A1|66%3A2|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
Michael Marchant
Sunday, June 07, 2009 - 06:58 pm, by:  Michael Marchant (Mavric) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not even close im afraid. As mentioned in my previous post I used about 2-2.5 bulk packs along with assorted other dynamat products. The doors are huge and take a lot to cover, let alone the floor and boot.
David Grab
T78
Reg: 01-2008
Monday, June 08, 2009 - 12:12 am, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Michael only thing i dont understand is the deliner that you used. I was planning on doing the whole car in just extreme and use those defussers. Why did you use the deliner?
Michael Marchant
Monday, June 08, 2009 - 08:12 pm, by:  Michael Marchant (Mavric) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The main reason I used the dynaliner was to reduce the amount of heat coming up through the floor. It also acts as sound absorbsion/difusion.
