  Soarer Central * ICE - In Car Entertainment * ICE Chat * Standard speaker wires, colours? Previous Previous    Next Next
Walter Gillmore
TT JZZ30
Reg: 07-2009
Tuesday, August 25, 2009 - 11:58 pm, by:  Walter Gillmore (Cl33pa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
g'day guys. i have a question. does anybody know the colours of the standard speaker wires at the amp plug?? ie, front left, front right, rear left, rear right and sub?
cheers. car not being at home i'm trying to cut down time so i can get the car on the road already. get much more done with this info on hand.
Brian Rignall
Reg: 12-2009
Tuesday, February 23, 2010 - 01:10 pm, by:  Brian Rignall (Cashmere) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hope this helps you... notice that your post is unanswered from August 2009.
application/pdfUpload
radio wiring.pdf (72.0 k)
Walter Gillmore
TT JZZ30
Reg: 07-2009
Tuesday, February 23, 2010 - 06:26 pm, by:  Walter Gillmore (Cl33pa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hahah thanks for the reply mate. i sussed it all out anyways and am using my carpc and a 5channel digi amp with the standard speaker wiring. :-) blew my standard sub the other day tho.... smokey smokey.
