  Soarer Central * ICE - In Car Entertainment * ICE Chat * 86280-24130 component under shelf in trunk. Previous Previous    Next Next
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Tuesday, January 05, 2010 - 03:14 pm, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://homepage.ntlworld.com/noctiluca/Soarer/EXtoyota4/localf~1/download/extoyo~1/wwwelc~1.ru/toyot a/cod~1400.htm
This is located under the self in the trunk above the gas tank to the drivers side of the Sub. What is it part # 86280-24130. It doesn't look to be connected to anything
Ali Saeed
Tuesday, January 05, 2010 - 05:19 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
amp for the sub?
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Tuesday, January 05, 2010 - 05:36 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sounds like the sub amp to me..
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Wednesday, January 06, 2010 - 03:39 am, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, Part 86280-24130 Is definitely the Subwoofer Amplifier
Dale Holan
Alberta
2.5 GTT L
Reg: 06-2007
Wednesday, January 06, 2010 - 05:21 am, by:  Dale Holan (Xtrax) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Are there two amps in the trunk? One for speakers(under CD changer) and one for the sub?
Michael Toet
Reg: 06-2009
Wednesday, January 06, 2010 - 07:18 am, by:  Michael Toet (Myke31) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep, one under the parcel shelf for the sub, one under the stacker for everything else.
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Wednesday, January 06, 2010 - 09:21 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dale Holan wrote on Wednesday, January 06, 2010 - 05:21 am:
yes.
Brian Rignall
Reg: 12-2009
Tuesday, February 02, 2010 - 07:53 am, by:  Brian Rignall (Cashmere) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Depending on what you have installed: there will be (visible) the CD Changer at the right hand side of the boot, under which is located one Amplifier.
From what I have seen in various manuals, some models have an amplifier under the back seat base cushion and others have one under the parcel shelf.
