Wednesday, May 11, 2011 - 06:15 am, by: Matthew Sharpe(Madmatt)
On my HTC DHD I find wireless mobile streaming over HSPA/HSPA+ is fine, but as soon as it drops to 3G it gets too laggy - and unfortunately so much of NZ's Vodafone network doesn't have HSPA let along HSPA+. Having the FM tuner is definitely useful sometimes, if I run out of podcasts to listen to.
Saturday, May 21, 2011 - 03:05 pm, by: Chris Lock(Sledge)
Ok, with the soarer speakers, the wires (at least in the drivers door so far), are grey and blue/grey. Which is the positive and which is the negative? Or how do i work out which is which? Cheers
Actually i think it might be easier to work it out wire side rather than speaker side as i found this: http://www.lextreme.com/Lexradiowcd.pdf RF+ LTGRN RF- BLU LF+ PINK LR- VIO RR+ RED RR- WHT LR+ BLK LR- YEL SUB+ RED/WHT SUB- BLK/WHT
Sunday, May 22, 2011 - 05:07 pm, by: Chris Lock(Sledge)
hrmm Toyota change wire color under the rear parcel shelf so i cant see what's what.. http://i54.tinypic.com/es6b9x.jpg Does anyone know which is positive and which is negative? Cheers
Monday, January 09, 2012 - 01:27 pm, by: Robert Faggian(Tanooki_suit)
These tiny and cheap ($25) motherboards will be available soon. Comes with a HDMI video out and one USB port. Supposedly powerful enough to handle Quake III, so should be ideal for car-pc's.
Friday, March 16, 2012 - 03:11 am, by: Aiden Cheese(Chillpen)
Who listens to radio :s
I think i remember a station or two from 1999, i think one was JJJ and another was MMM there's probably a ZZZ somewhere...
All i know is the music selection is rubbish on the radio, and for less than 5gb per month, i can stream unlimited radio if i wanted. Maybe not 100% unlimited, because the fuel cost of running the car all month would far outweigh the cost of a 29 data plan. But you know what I mean.
Mostly, with the library of several thousand songs, i wouldn't understand why anyone would spend nearly a grand (or more after amps and speakers and wiring) on modifying their sound system to then say "I'll just run FM on it". At least do digital.
Friday, March 16, 2012 - 10:31 am, by: Dave Rose(Sand_groper)
Just buy a DAB+ digital tuner ($180) , 40+ channels in Perth,no hiss clicks etc sound is same or better than CD, bass is perfect going through the Soarer sound system. Never listen to Fm .
