  Soarer Central * ICE - In Car Entertainment * ICE Chat * Stereo in.Working.Now no sound! Previous Previous    Next Next
Greg McNamara
TT GTE ZZ30 2.5l
Reg: 06-2012
Monday, December 10, 2012 - 09:09 pm, by:  Greg McNamara (Maccamenzies) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Now this is weird.I have installed single din Kenwood all wired up and working.Sound through speakers.
Come out to the car today and no sound through any speakers.
Unit is not running through any amps and speakers are running straight to the single din head. I can see the unit is working sound level meters are going up and down etc. No sound through speakers.This applies even if on radio or cd.
Not sure why. Has anyone had this problem????
Vincent Chan
v8
Reg: 12-2010
Tuesday, December 11, 2012 - 09:25 am, by:  Vincent Chan (Vincent191) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
One of the audio output sockets have come loose?? Check the wires to the speakers.
Tom Richards
Tuesday, December 11, 2012 - 11:38 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is there a mute button?
Peter Bullman
Tuesday, December 11, 2012 - 07:03 pm, by:  Peter Bullman (Pete) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I 2nd the above.. check to make sure the mute button hasnt been pressed.
I doubt it is an 'output socket' as the loom has all the wires, including power, on the same plug. So if there's power there should be sound.
Greg McNamara
TT GTE ZZ30 2.5l
Reg: 06-2012
Thursday, December 13, 2012 - 11:14 pm, by:  Greg McNamara (Maccamenzies) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
looks like it may have been the radio itself even thought all the functions were working and lighting up.blown outputs!!! dam in i know why.So now shopping for another radio.
Greg McNamara
TT GTE ZZ30 2.5l
Reg: 06-2012
Tuesday, December 25, 2012 - 12:53 pm, by:  Greg McNamara (Maccamenzies) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nope.Wasnt the radio.I replaced it with brand new unit and all was working. Was even working as late as yesterday. Come out today and same again.No sound. Can anyone tell me wether the speakers go through some form of amp or preamp after the front console harness??? Driving me nuts.
Thanks
Greg Perth
Greg McNamara
TT GTE ZZ30 2.5l
Reg: 06-2012
Wednesday, December 26, 2012 - 02:24 pm, by:  Greg McNamara (Maccamenzies) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Vincent hit the nail on the head.It was ONE loose speaker wire on the right rear parcel shelf making and breaking contact.
Seems when one wire goes down they all stop working.
Hope this helps someone in the future
