  Soarer Central * ICE - In Car Entertainment * ICE Chat * EMV Replacement - Audio pinout Previous Previous    Next Next
Richard Thomas
Reg: 11-2012
Monday, December 29, 2014 - 05:35 pm, by:  Richard Thomas (Errant) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
I'm doing an EMV swap in my UZZ31, and everything basically hunky dory (Climate control out of a TT, etc.) except that I can't actually get the head unit working, it's giving me an error about miswiring when using the PC2-17-4 adapter. Worked fine in the TT and as far as I know the EMV's audio gear should be standard Toyota generational ISO, is this not the case? Is there a pinout for EMV-equipped Soarers that I should be comparing against?
Richard Thomas
Reg: 11-2012
Wednesday, December 31, 2014 - 12:02 am, by:  Richard Thomas (Errant) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ahahaha. Okay, so what's actually happened here is that I had two sets of spliced ISO harnesses. They LOOK the same, but they're actually different, because one head unit's from 2009 and the other's from 2012 and JVC changed their layouts slightly.
Vincent Chan
v8
Reg: 12-2010
Wednesday, April 25, 2018 - 08:13 pm, by:  Vincent Chan (Vincent191) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just had my EMV replaced with a after market unit. Found a great guy and he did a great job. He is in Sydney and will come to your home.
