Tuesday, July 21, 2015 - 08:50 am, by: Tom Richards(Tomr)
it works great, but i have been "collecting" the pcs to do the EMV conversion.
I can sell the emv to pay for the conversion. The unit i am looking at has GPS, USB input(mp3, mp4),DVD player, Bluetooth, Sub out, reversing camera input,aux in to take my Dig tv, and i think with out needing expanders, better radio reception with station names displayed etc.
You gain some useful functions, and only lose the trip functions on the EMV
Mike Beck Goo Roo New Zealand UZZ32 No.32 & JZZ31 3.0GT
Tuesday, July 21, 2015 - 07:38 pm, by: Justin Prewett(Buzzbox)
I gather you'd just need to find the correct wiring diagram for your UZ model / year and tap into the L/R audio out from the EMV that runs to the amp. i've got my aftermarket headunit wired into the factory loom and then bypass the amp and back to the speakers. the headunit on its own is loud enough for me and i have an aftermarket amp running the sub so that i can put the big 12" in the boot if i want more bass.
here's how my Sony headunit fits in the factory double din trim (in a JZZ30).
Tuesday, July 21, 2015 - 10:10 pm, by: Roland Elliott(Aussie2013)
Tom Richards wrote on Tuesday, July 21, 2015 - 08:50 am:
"and only lose the trip functions on the EMV" There are a lot of functions on the EMV that would be lost, You have bypassed the AC so you still have that but assuming you have this on the 32 your othe computers will not communicate with the EMV on the other functions.
Wednesday, July 22, 2015 - 07:52 am, by: Tom Richards(Tomr)
to use the existing amp for the 4 speakers , I believe from the RCA o/p on the head unit , i connect to the amp under the CD player. A1 FR red A2 FL Blue A7 RR brown A8 RL white
woofer amp connections are
pin1 RU+ black pin5 RU- white
to connect to the RU inputs, i need to change the unbalanced WF o/p from the head unit to a balanced I/P to the sub amp (RU + and RU-)
This can be done using an op amp, DVR134, and 2 10uf caps
Monday, August 03, 2015 - 11:19 am, by: Tom Richards(Tomr)
i have connected the pre amp O/P's (rca connectors) and the SW to the D plug on the radio receiver under the rear seat.(i used cat5 twisted pr and run it under the carpet along the LHS sill)i did not earth it at this end, but earthed pin 9 of the plug. I only used RU+ for the sub connection and it seems to work ok. This is the I/P to the power Amp under the CD stacker. All speakers and S woofer are now driven with the stock amps.
I cannot locate the Reverse camera video to the EMV so will have to run another wire to the camera via the RHS sill.
